Replacing rear speakers - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Aug 19th, 2006, 10:51 AM
Local Time: 01:44 PM
United Kingdom View djwoody's Classified Ads
United-Kingdom Replacing rear speakers
I am wanting to replace my rear speakers in my Cooper S with some Pioneer ones.
I have looked on the pioneer website and in the brochure it says that the TS-A6901 speakers will fit but are Universal.
Does this mean that i will have to buy an adaptor plate as well? If so, which adaptor plate will i need and where in the UK can i get them from?
Regards
Chris
Old Aug 19th, 2006, 05:36 PM
DaFlake's Avatar
MMC Member
Local Time: 09:44 AM
Do you have HK or standard radio?
Old Aug 19th, 2006, 06:12 PM
United-Kingdom
Just the standard radio...
Old Aug 19th, 2006, 06:21 PM
DaFlake's Avatar
MMC Member
Universal 6x9 speakers should work just fine for your rears. These speakers will probably have the standard speaker interface which means that you would have to splice your wires.
However, I would check out www.newministuff.com and speak to Mikey. He can set you up with everything you need to fit your MINI correctly without hacking your wires. Give him a look but be advised that his wife just had a baby and he may be a little slow to respond.
Old Aug 19th, 2006, 07:26 PM
SteveM3's Avatar
Local Time: 02:44 PM
You can replace the existing 6x9 (except convertibles) and use the existing wiring.
You may find you need to enlarge the hole slightly or make a very thin template to
go between the speaker and the metal.
Old Aug 20th, 2006, 12:08 PM
G-Man's Avatar
Cool CoopS
England Male View G-Man's Dark Silver & Body Color 1st Gen MINI Cooper S Profile
Hi can you change HK speakers for different ones?
Old Aug 20th, 2006, 05:56 PM
SteveM3's Avatar
Yes but the HK speakers are bi-wired. Bi-wired means one set of wires for the large
speaker (commonly called the woofer) and another set of wires for the small speaker
(tweeter). You can bi-wire any 2 or 3 way 6x9. Some 6x9's will be ready for bi-wiring,
usually the more expensive ones. If a speaker isn't bi-wired ready then you can snip
wires and do a bit of soldering. If in doubt go to a good car hi-fi dealer and pay a
little more than mail order but they will be able to show you what to do.
Old Aug 20th, 2006, 06:38 PM
mikeythemini's Avatar
You can't change the HK speakers for normal aftermarket ones or you will blow the HK amp - HK amp is designed to work with 2ohm speakers not 4 ohm which most aftermarket ones are
Most 6*9s will physicaly fit in the rear positions but as Steve points out, some are slightly too big.
I keep wire plug adaptors to save you chopping the factory speaker plugs off
Old Aug 20th, 2006, 06:41 PM
DaFlake's Avatar
MMC Member
Thanks Mikey and congrats. You getting sleep yet?
Old Aug 20th, 2006, 07:00 PM
G-Man's Avatar
Cool CoopS
Thanks Mikey. So it's best to leave the HK speakers in. To be honest the HK speakers are great.
Old Aug 23rd, 2006, 11:04 AM
PMB's Avatar
PMB
Isle of Man Male
Actually, by fitting 4 Ohm speakers to a HK system you will be more likely to blow the speakers. This is because at 4 Ohms the 2 Ohm amps will only put out about half the power and cause distortion that is likely to damage the speakers, especially the tweeters. To the amplifler a 4 Ohm load is easier to drive than a 2 Ohm load, so no danger to the amp.
If you have an HK system and want to replace the 6x9s the Infinity 693.7 is a very high efficiency 2 Ohm speaker that makes the HK stock sound rather inadequate. The 693.7i can also be connected up to a Boost system without damage provided you don't run it turned up to 11 all the time.
Old Aug 23rd, 2006, 11:13 AM
DaFlake's Avatar
MMC Member
Actually, I agree with Mikey. A 4 Ohm speaker will blow the amp as it works harder to drive the speaker. Not that I plan on testing this theory. However, it is nice to know that there are some other speakers out there. Have you used these in an HK system?
Old Aug 23rd, 2006, 01:20 PM
PMB's Avatar
PMB
Isle of Man Male
Amplifiers do not drive speakers, speakers draw power depending upon their impedence (resistance) and sensitivity. The more resistance between the + and - terminals on the amp., the less power (current) can be drawn 2 Ohms offers less resistance than 4 Ohms, which in turn offers less than 8 Ohms. If you connect the + of the amp directly to the - of the amp ( 0 Ohms) it will either shut down in safe mode or blow.
When you connect 2 similar speakers in parallel there are two paths for the electrical current to take which effectively halves the resistance, therefore 2, 4 Ohm speakers in parallel offer a 2 Ohm load. When the sam e speakers are connected in series the electrical current has to pass through twice the resistance so the 2, 4 Ohm speakers offer an impedance of 8 Ohms. There is a little more to it than this but this is a good rule of thumb.
The biggest resistance is of course having no speaker connected at all!
Old Aug 23rd, 2006, 02:09 PM
DaFlake's Avatar
MMC Member
I understand that a 8 ohm speaker could and will be destoyed by an amp that can't provide the power. If I remember correctly this is called clipping. Distortion that rips the speakers to shreds. However, I have also read many threads about people that have swapped the speakers in a HK MINI only to turn the system on and smoke the amp. These people even put the old speakers back in and were forced to buy a new HK amp. So what would cause this?
Just trying to get this all straight in my head and learn.
  #15 (permalink)
Old Aug 23rd, 2006, 04:12 PM
PMB's Avatar
PMB
Isle of Man Male
The HK system uses mulitple amplifiers and it is likely that in replacing the speakers they have joined the output of two or more of the amplifiers together causing effectively a dead short. This will fry the output transisters / ICs.
Replacing Rear Speakers Gary90 First Generation Interior & Ice 6 May 24th, 2007 05:59 PM
Is it worth replacing the stock speakers with new Co-Axials? feenster First Generation Interior & Ice 13 Jul 6th, 2006 09:19 AM
Replacing factory speakers, looking for the DIY's SSJ First Generation Interior & Ice 4 Oct 14th, 2005 09:58 AM
replacing door grilles and fitting speakers in their place A13EX F Cooper S First Generation Interior & Ice 22 Sep 4th, 2005 01:13 PM
Advice on replacing the stock speakers MiniPowers First Generation Interior & Ice 1 Jan 15th, 2003 09:13 PM
