| IF this is factory tint (colored glass and not paste on's) the best method that I have found for any tint or sticker is a hairdryer. Working from top to bottom, heat a small area and start to peel it back. If this is a aftermarket tint, then it gets a little more tricky and TBH, I would have the dealer that was dumb enough to put a sticker on it remove it. |
| Thanx guys for your suggestions, yes they are authentic factory tints from mini so hopefully it will make removing a lot simpler.... i told the dealer to take it off which they had a go at but it looks as though the tints were sticking to the sticker...silly fools |
| To get the sticky bits off I use the stickers themselves. for some reason the glue on the back of the sticker will stick to the glue on the surface and peel it off. Try it on any sticker next time oyu take one off. Just keep pressing the sticker back onto the glue and pull it off. works every time. |
| Dealership rear window sticker | matt.morrow | First Generation MINI Cooper | 26 | Oct 27th, 2004 10:45 PM |
| Removing Dealer Sticker From Rear Window | El Gordo | General Discussion | 20 | Oct 27th, 2004 03:49 PM |
| Rear window name sticker ! | mini_magik | General Discussion | 8 | Apr 19th, 2004 06:30 AM |
| UnionJack sticker wanted - inside on rear window | Dennis77 | General Discussion | 10 | Nov 18th, 2003 09:46 PM |
