4 speaker outputs.... 6 speakers??? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 25th, 2006, 02:26 AM
Local Time: 01:45 PM
Hello all,
I'm getting ready to buy and install an Alpine CDA-9857.
I've got new infinity tweeters and 5 1/4" 2-ways in the doors. I plan to buy some new 6X9s for the rear.
I'd like to push these 6 speakers from the head unit. My door speakers are not true components, so there's no crossover.
Can I just run the 5 1/4 and the tweeter for each door off of one speaker output? or will that change the Ohm load on the amp in such a way that I'll fry something?
I'm planning on Only amping my sub at this time due to the fact that I'm currently amping my front speakers and picking up too much RF noise due the the amp on top of the battery (MCS),,, which causes some annoying whine. (which isn't showing up in the sub)
Thanks for any advice,
Donald
Old Sep 25th, 2006, 01:16 PM
Local Time: 09:45 AM
There *is* a crossover for your new Infinitys; it's just built in to the speaker and not a separate box. Probably only a little capacitor.
No problem running them from the factory HU - the capacitor filter means you're not actually driving two 4 ohm speakers from one output. The factory speakers are just the same (look carefully at the tweeter in the top of the door and you'll see a capacitor filter attached to it).
Old Sep 25th, 2006, 04:56 PM
Thanks Ian,
You've confirmed what I was hoping.
My tweeters do have a capacitor type crossover inline...... once again your knowledge and helpfulness is appreciated.
Donald
Tags: , ,
Which is the live wire in the front and back speakers as im fitting new speakers fozworth First Generation Interior & Ice 3 Feb 10th, 2009 10:04 AM
Early and late S power outputs - what changed? CoolCarStuff First Generation MINI Cooper S 9 Oct 18th, 2006 03:23 AM
Replacing main front door speaker with non-component speakers beebleb First Generation Interior & Ice 5 May 28th, 2005 01:51 PM
GT4 Vehicle power outputs Dutchy MINI in the Media 9 Apr 21st, 2005 12:47 AM
H/K Head unit outputs Nick-o First Generation Interior & Ice 2 May 19th, 2004 10:12 PM
