I have a set of JCW front seats and the airbag light stays on can i just remove the - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Oct 9th, 2006, 08:12 PM
Local Time: 01:46 PM
United Kingdom View fozworth's Classified Ads
As my JCW front seats dont have air bags in ,the computor thinks theres a fault.and the air bag light stays on.BMW want to charge an hours labour just to down load a code to turn the light off.and at £95 per hour plus vat i ant going to use them.So i wonderd if i could just remove the fuse in the fuse box or will this deactivate the airbag.or is there a seperate one for the light.
Old Oct 9th, 2006, 08:49 PM
mikeythemini's Avatar
Local Time: 02:46 PM
If the light is on or you remove your fuse you loose all the airbags & the seatbelt tensioners. This could give you insurance issues
Old Oct 9th, 2006, 08:52 PM
Rakey's Avatar
Total MINI dot com!!
United Kingdom Male View Rakey's Classified Ads
who fitted the seats?
if they were dealer fit then they should have sorted this out.
my dealer did the deactivation free of charge, even though they didn't do the fitting of the seats, but the average price they should charge is about £40, its a 5 minute job, the hardest thing is the paper work they have to do
Old Oct 9th, 2006, 09:05 PM
jamestyler's Avatar
United Kingdom Male View jamestyler's Hyper Blue & White 1st Gen MINI Cooper S Profile
It could also cause you death issues No seriously if planning on hitting something it is probably best to have all the cars safety features working (I know you have taken out the side airbags, but frount airbags and pretensioners are pretty important)
Old Oct 9th, 2006, 10:35 PM
Berthil's Avatar
Netherlands Male View Berthil's Electric Blue & White 1st Gen MINI Cooper S Profile
There is a trick where a 4 ohm resistance is put in the open plug. The computer then thinks the airbag is still there so no light lit.
Just be carefull NOT to put current through the system when you are measuring with a volt meter to see where the resistance must go. This could trigger other airbags to go off I have read.
Not that I have done this myself, I had the dealer disable the side-airbags.
EB/W R53 MCS Highly Modified
Old Oct 10th, 2006, 11:46 AM
Neil the Hat's Avatar
United Kingdom Male View Neil the Hat's Classified Ads
Once the light is one you have to go to the dealer.
If you had not turned on your ignition after fitting the seats then a resistor would work.
You have no choice now!
Old Oct 10th, 2006, 12:53 PM
DaFlake's Avatar
MMC Member
Local Time: 09:46 AM
There is a tool that will let you reset the thrown fault code (about 150 USD I believe). However, if you do it and it comes back, then you have an issue that needs repair. If the seats were fitted by MINI, then it should be under warranty.
Old Oct 10th, 2006, 02:33 PM
The only people that can do this job with a code are the main dealers and my main dealer charges £100 per hour with the vat and said that it would be an hours labour.regardless
Old Oct 10th, 2006, 04:31 PM
United Kingdom Male View robby71's Classified Ads
Where abouts are you? there's a BMW specialist in Huddersfield who charges £10 to put out the light
Old Oct 10th, 2006, 06:22 PM
Im in bristol mate,Apparently they have to send off to bracknell main office and get a code ,which they then program into my car,but as the dumb ass's dont know their **** from theie elbows they have told me it will be a hours labour so im no way paying £105 including the dreaded
Old Oct 10th, 2006, 07:30 PM
DaFlake's Avatar
MMC Member
I stand corrected. The tool that I was thinking cannot reset the airbag light. A trip is necessary.... As Robby stated, you need to shop around and find a dealer that is willing to do it cheaper.
Old Oct 10th, 2006, 09:46 PM
Damo's Avatar
Lights are on but...
Send a message via MSN to Damo
United Kingdom Male View Damo's Solid Black & White 1st Gen MINI Cooper S Profile View Damo's Classified Ads
I've had it done 3 times. (Once to deactivate on Cooper, once to reactivate on Cooper and once to deactivate on S.) All 3 times it cost me less than £50 Think it was about £35-£40
Old Oct 12th, 2006, 08:22 PM
Carer of Millie the Mini
Scotland View johnsop1's Cosmos Black & White 1st Gen MINI Cooper Profile
Try here
AIRBAG SIMULATOR
New Seats and Airbag Light.... Help! MiniDoug First Generation Interior & Ice 10 Sep 13th, 2007 07:37 PM
Have fitted JCW ,airbag light stays on?? fozworth First Generation MINI Tuning 11 Aug 24th, 2006 08:10 AM
Aftermarket seats with Airbag Light wrecky First Generation Interior & Ice 3 Dec 19th, 2005 11:04 AM
Foursome front light set up!!!!!!!!!!!!!!!!!!!!!!!!!!! mancjimmy First Generation MINI Exterior 0 Jul 6th, 2003 06:00 PM
