Fitting the Aux Adapter - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Nov 22nd, 2006, 01:58 PM
minijon's Avatar
Local Time: 02:48 PM
United-Kingdom Fitting the Aux Adapter
I have trawled the threads on how to fit the Aux adapter to my RHD 06 MC. Some threads say to remove the glove box and plug the adapter in through the top of the head unit, the other threads say to remove the HU. Please advise me the easiest route for me to take.
Regards
Old Nov 22nd, 2006, 02:46 PM
MisterMINI's Avatar
Keith
Local Time: 09:48 AM
United States Male View MisterMINI's Chili Red & White 1st Gen MINI Cooper S Profile
I think the easiest way to plug the adaptor into the head unit on an 06 model is to remove the head unit. This is really easy. Remove the 4 torx screws (2 on each of the down tubes) push the down tubes up and out thus revealing the 4 screws that hold the head unit in place. Remove those 4 screws and the head unit will then slide out.
If you want to install the aux jack in the glove box then the glove box will need to be removed. I left mine behind the dash because I have no need to keep plugging and unplugging my ipod cable. I was concerned that the cable might flap around and rattle, so this is what I did to secure it. If you open the drivers door and remove the plastic panel from the end of the dash board you will be able to see behind the dash. You will see there is an aluminum bracket with 3 holes in it. The smaller of these holes is about 1/8th inch too small to receive the aux input jack, so I drilled it out and now the jack is held securely in place with the locking nut that came with the jack.
MINI Aux Adapter available!! sprocket First Generation Interior & Ice 47 Jun 1st, 2004 01:32 AM
Can Someone get me the Aux Adapter? ChilliSteve Midwest Region 2 Apr 16th, 2004 10:07 PM
AUX Imput Adapter giorgiorichelli First Generation Interior & Ice 1 Mar 3rd, 2004 07:32 PM
AUX Adapter in Europe question Don First Generation Interior & Ice 33 Dec 27th, 2003 08:23 PM
