+5v Source - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Dec 15th, 2006, 04:08 AM
Kevin
Local Time: 06:48 AM
Canada Male
Canada +5v Source
Does anyone know if theres a +5v source in the dash/stereo area capible of supplying ~ 1A peak power?
Before I go grab a 12v->5v dc-dc converter just thought I'd ask. I'm trying to find a place to perma-connect my Magellen eXplorist 500 gps.
Old Dec 15th, 2006, 01:33 PM
Local Time: 09:48 AM
I'm sure there isn't.
It's possible some of the electronic modules have 5V internally, but that supply won't be made available externally - and 1A is the top limit for most 5V regulators anyway; they'd need a good heatsink.
Old Dec 15th, 2006, 06:59 PM
Kevin
Canada Male
Canada
I'll probably just canabalize a retail cig-adapter designed for the unit then, but what regulators are you using for your mini circuit (that looks quite cool btw).
What would you recommend for a 12v->5v @ ~1Amp -- regulator. Operating temperature range is critical because it gets both extremely cold and hot here in Edmonton.
Also, would you splice into the cig feed or is there a better 12v source at some connector that wouldnt require a splice.
TIA
Old Dec 15th, 2006, 10:05 PM
The MINI circuit only draws about 20mA.
For my TomTom I used a small module which has three pins just like a 7805, but is internally a switching regulator so very low heat dissipation. I don't remember the part number now and the only similar part I've found is this, which is not identical but might work for you:
Switching voltage regulators - 7805 replacements
Old Dec 16th, 2006, 05:04 AM
Kevin
Canada Male
Canada
Was PT5101A-ND the one you used (Digikey part #)?
Where else to source used Mini's? BRG/Blk Cooper S General Discussion 6 Dec 15th, 2006 08:40 AM
Power Source L33 KBY First Generation Interior & Ice 2 Mar 18th, 2006 10:09 PM
Source switch on new MFSW DaveN First Generation Interior & Ice 5 Aug 16th, 2004 02:06 AM
CD changer source? Gary Tate First Generation Interior & Ice 2 Jul 29th, 2002 10:46 PM
