Retrofit OBC - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 15th, 2007, 10:08 PM
the-ruff-puppy's Avatar
The ruff puppy & MINI
Send a message via MSN to the-ruff-puppy
Local Time: 01:49 PM
United Kingdom Male View the-ruff-puppy's Cosmos Black & Body Color 1st Gen MINI One Profile
Retrofit OBC
eBay.co.uk: Bmw Mini Retro-Fit On Board Computer Light Stalk (item 220070664966 end time 21-Jan-07 17:21:38 GMT)
Considering buying this (the one option I really wish MINI had!)
The seller says a wiring harness kit is required, I thought it was a straight swap? If it is needed, can I buy this alone?
Many thanks in advance
Old Jan 16th, 2007, 06:59 AM
Yellow and Proud
Send a message via MSN to MartinSSZ Send a message via Skype™ to MartinSSZ
Local Time: 02:49 PM
United Kingdom Male View MartinSSZ's Liquid Yellow & Black 1st Gen MINI Cooper S Profile View MartinSSZ's Classified Ads
Yes you can - it's part number 61 12 0 140 552 and about £20 from a MINI/BMW dealer.
Definitely worth buying the stalk from eBay as they are over £80 from the dealer
Old Jan 16th, 2007, 08:15 AM
Send a message via MSN to 1andy
United Kingdom Male View 1andy's Classified Ads
England
What does this do??
give you how much fuel your using and the average speed etc?
Old Jan 16th, 2007, 09:46 AM
Thanks guys
Old Jan 16th, 2007, 04:18 PM
chris.lamb's Avatar
United Kingdom Male View chris.lamb's Chili Red & White 1st Gen MINI Cooper S Profile
Martin,
If you already have a steerng column mounted tacho with temp display then surely you don't need the harness you mention?
Old Jan 16th, 2007, 04:59 PM
Yeah, I have that bit...
Old Jan 16th, 2007, 05:14 PM
I shall wait and see what comes in the box, hopefully it'll work out nicely
Old Jan 16th, 2007, 05:49 PM
CoolCarStuff's Avatar
Flying Scotsman
Scotland View CoolCarStuff's Classified Ads
Yeh...you still need the wiring, even with the tach...
The wires run (min if you do it DIY rather than buy the factory loom...) is a wire from the stalk to the back of your speedo....
You also need the car coded to activate it, unless you are very lucky....
DJ
Old Jan 16th, 2007, 06:41 PM
Yellow and Proud
Quote: Originally Posted by chris.lamb (original)
Martin,
Yes you do, as the harness basically connects the new stalk button to the back of the large speedo dial which then drives the rev counter display to give you the new info
Old Jan 16th, 2007, 06:48 PM
Yellow and Proud
Ooops - CCS got there first
Old Jan 16th, 2007, 07:09 PM
Isle of Man Female
I have a R54 Cooper which has the OBC lever. It just toggles between the external temperature and the speed. I took this to mean that I haven't got the full OBC spec, so could I have the rest of the features such as MPG etc added? Or does it just need reprogramming to show more than it's doing now?
Old Jan 16th, 2007, 07:30 PM
Yellow and Proud
Yup, just needs reprogramming to give you the full OBC
Not sure what an R54 Cooper is though!
Old Jan 18th, 2007, 11:20 AM
chris.lamb's Avatar
I stand corrected!
Old Jan 23rd, 2007, 09:30 AM
Mat-CooperS's Avatar
I love Mini dealers!!!
I've just rang my local BMW/Mini dealer RE retro fitting the OBC. They have quoted me £276.20 for the indicator stalk, wiring kit and fitting. I asked for the price of the stalk on its own which is £99.95, so I then asked if I obtained the stalk elsewhere (i.e off ebay) how much would the wiring kit cost + fitting. The woman told me they order it as a kit so they wouldnt fit it if I got the stalk myself! I told her I had the part number for the wiring on its own, "no sir it is supplied as part of a kit and you can not get it on its own, we will not fit it if you supply the parts"!
OBC DIY retrofit warning monsta First Generation Faults & Fixes 1 Mar 3rd, 2005 10:56 AM
Retrofit OBC danb First Generation Interior & Ice 2 Feb 19th, 2005 03:43 PM
OBC Retrofit reidu First Generation MINI Cooper S 9 Dec 6th, 2003 10:52 AM
Range option for OBC retrofit? DAVEE First Generation Interior & Ice 8 May 9th, 2003 12:59 AM
OBC retrofit suprchrgdmini First Generation Interior & Ice 9 Nov 21st, 2002 02:24 AM
