Richbrook Chrome Tax Disk Holder - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 10th, 2007, 07:34 PM
Local Time: 02:49 PM
United Kingdom View MINIALEX's Dark Silver & White 1st Gen MINI Cooper S Profile
Hi all,
Am having problems fitting my Richbrook tax disk holder to my windscreen - its comes with 6 red one sided sticky bits and one clear - I can't figure this out - any clues??
Cometh the Hour, Cometh the MINI
Old Feb 10th, 2007, 11:09 PM
ScottyBoy's Avatar
Obsessive Car Cleaner OCC
Usually you stick the 6 sticky pads on the holder and then to the windscreen and presto it sticks! or have you bought a dud set! ...
Old Feb 10th, 2007, 11:12 PM
MiniMinor's Avatar
3 new text messages from.
Send a message via MSN to MiniMinor
England Male View MiniMinor's Hyper Blue & White 1st Gen MINI Cooper S Profile
Im sure the pads come with Red peel off bit one side and Clear ones on the other side.. Mine did.
And if i remeber right they take a bit to peel off. Just try pecking at the edge..
Old Feb 11th, 2007, 02:16 AM
Rakey's Avatar
Total MINI dot com!!
United Kingdom Male View Rakey's Classified Ads
On mine I have only used 3 pads, the spacer been used on the lowest, but on my GF's car we have used all of them , again with the spacer on the bottom sticky bit, hope this helps
Old Feb 11th, 2007, 10:22 PM
S12 GMM's Avatar
Local Time: 01:49 PM
United Kingdom Female
Peel 5 of the red backed discs off their backing and stick over screw heads, then use a very sharp knife/razor blade to peel off the red backing. use the clear spacer on the bottom sticky pad to take account of windscreen curvature and place the 6th sticky pad on top of the spacer. Stick to windscreen and hold in position for a few minutes until stuck. Hope this helps.
Putting new tax disk in old chrome tax disk holder - is it hard?! Intrepid General Discussion 27 Feb 10th, 2005 12:41 PM
help required for my wide boy tax disk.... MiniJamie General Discussion 16 Feb 1st, 2005 04:07 PM
