| Hi Do you mean the integrated speedo/rev cluster mounted on the steering column or the discreet units? The Speedo is coded to the BCM, if its the centrally mounted instrument - the cluster is behind it. If you have the speedo "pod" on the steering colum, the instrument cluster is part of the chrono pack or satnav unit - so either way, you are into coding (and worse) if you change them out. The steering wheel mounted speedo/rev counter units are not difficult to swap - no instrumentation control is in there - they are only "slave" display units. You do need to code them, however, as they wont display the correct warning lights etc if you just swap them. What is it you are trying to achieve? Hope that helps..... DJ Last edited by CoolCarStuff; Feb 14th, 2007 at 08:04 PM. |
| Hi, Thanks for the information. I don't have the sat nav so it is the central speedo I am asking about. I was trying to change out my dash lights and was going to get a speedo to work on and then just change them over. I think I will now get it done through essentialmini though, if they reply to my emails that is! ![]() |
| Looking for a set of speedo/rev clocks | Tommygun3562 | General Discussion | 1 | Jun 4th, 2007 05:14 PM |
| Speedo in rev counter on 52 MC | MOCKSY | First Generation MINI Cooper | 2 | Dec 20th, 2004 12:56 PM |
| Speedo in Rev Counter Retro | bobnobski | First Generation MINI Cooper S | 4 | Sep 23rd, 2003 09:22 PM |
| Change from Rev Counter only to Rev + Speedo on column | GordonD | First Generation Interior & Ice | 1 | Feb 24th, 2003 08:43 PM |
| Speedo and Rev counter both packed up | Simon Jackson | First Generation Faults & Fixes | 2 | Nov 5th, 2002 12:25 PM |
