factory sat nav with aftermarket head unit? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 26th, 2007, 10:36 PM
Local Time: 09:24 PM
does anyone have factory sat nav with an aftermarket headunit? I am coming from a e39 BMW and have quite a good handle on the sat nav system in that which uses similar components, however the head unit side of things is a little different in the mini.. the E39 uses a monitor with controls and a cd or tape player, with controls for the cd changer/tv/radio and a remote radio module..
as I understand it the mini uses the same mk4 nav computer however I just noticed it also has a head unit... just wondering whether the system makes use of the same remote radio module (BM54) as the E38/39/X3/X5 or if there is an amp in the head-unit?.. also how the two are tied together, and if theres any control over the radio/cd/changer through the nav computer...
Im thinking the screen is purely for nav video from the nav computer while the radio deals with amplification, playback, control, etc...
if someone could clarify the inner-workings and how I got this around my neck so bad I apreciate it!.. Also the implications in terms of connectivity of using the factory nav with an aftermarket head-unit, or if its exactly the same...
b
Old Feb 27th, 2007, 06:44 PM
DaFlake's Avatar
MMC Member
Local Time: 04:24 PM
The radio only provides a voice outlet for the nav. They are also tied together for the phone interface, but that is it. If you pull the radio, you can still control and use the nav (minus the voice).
Old Feb 28th, 2007, 10:06 AM
thanks for the reply... Is there no way to send the voice back through an aftermarket head unit?.. Im assuming there is a mute wire to cut the audio and then the audio out of the nav computer is connected to an aux input of sorts at the head unit...
Old Feb 28th, 2007, 08:03 PM
DaFlake's Avatar
MMC Member
No way that anyone has figured out.
Tags: , , , , , , ,
Lost Nav Voice - new HK head unit and new Nav dinasurfing First Generation Interior & Ice 5 Aug 2nd, 2006 10:20 PM
Question for people with factory Sat Nav and aftermarket HU MartinSullivan First Generation Interior & Ice 4 May 22nd, 2005 02:56 AM
Aftermarket Head with Sat Nav??? Will it work??? GeoffMM First Generation Interior & Ice 1 Mar 7th, 2004 02:53 PM
HK with aftermarket head unit Liam"S" First Generation Interior & Ice 12 Jun 5th, 2003 11:04 AM
