what amps you running????? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Apr 16th, 2007, 01:25 PM
aid's Avatar
aid
**** You Mr Darling
Local Time: 10:45 PM
Scotland Male View aid's Classified Ads
Scotland what amps you running?????
Done the install in the MCS and ive got the dreaded whine from the rear 6x9's spoke to my installer and mikeythemini on this fourm and they said try moving the earth so i did that still the whine so he suggested switching the amp as he thinks it may be the amp that is the problem
im currently running a inphase amp for the 6x9s and thats the problem end but before i go spend 100 quid on another amp and it turns out that one doesnt work either im asking all of you
WHAT AMPS WORK? i.e no whine????????????
Old Apr 16th, 2007, 01:37 PM
drumzz's Avatar
Local Time: 11:45 PM
rockford fosgate power 851s
Old Apr 16th, 2007, 02:31 PM
aid's Avatar
aid
**** You Mr Darling
Scotland
ok looking to spend less than 100 quid for the amp!!!
Old Apr 16th, 2007, 11:08 PM
SteveM3's Avatar
Don't give up on the earth. There are many connections involved, any of which can cause
the problem. It is very likely if you buy a new amp you'll get the same problem. Ask around
if anyone has an old amp however cheap you can borrow to try. If it makes the same noise
save your money. The main earth to the amp is the most likely source but also check the
RCA cables, the earth at the headunit, the routing of the RCA cables and the power cable.
If you have any other equipment connected e.g. dual amp balancer also check all the
connections are good on that. Don't assume an earth contact good enough to make a
bulb glow is good enough for hi-fi. Try at least three different earthing points. Best of luck.
Old Apr 17th, 2007, 11:53 PM
i used to work for InPhase . Used to. Enough said.
im guessing, you tried to order something else and they talked you into buying the InPhase amp.
tbh, they arent bad. the InPhase speakers are certainly the best product they do though.
Im currently using an Opti 500d without trouble.
Ive had a lot of use of the InPhase products, literally. i used to drive the InPhase demo van, never came across that problem though.
Old Apr 19th, 2007, 02:48 PM
aid's Avatar
aid
**** You Mr Darling
Scotland
yeah exactly went to order kenwood amp and the sales guy talked me into the inphase amp had this problem from the same amp in my previous car (bmw e46 330ci) so im guessing the problem is the amp so ill be away to buy a new one this weekend so i can get the install finished and start on the handling of the car
cheers folks
Interesting engine running in article (running in = breaking in) R1 General Discussion 61 Oct 5th, 2009 09:18 PM
What amps have you fitted and where? dsakko First Generation Interior & Ice 8 Oct 23rd, 2006 11:57 PM
Under Seat Amps Trophy160 First Generation Interior & Ice 1 May 9th, 2005 07:56 PM
Grounding amps??? MikeJungle30 First Generation Interior & Ice 13 Feb 6th, 2004 11:12 PM
