| You can't get a better earth than that. At least it would serve to eliminate a bad earth as a cause. Try your friendly neighbourhood car shop. Go there with your headunit ready to remove and ask them if you could try another set of RCA's to diagnose the problem. Its not like you'd have to route them under the carpet or anything, just go across the seats from front to back. I know i'd only be too happy to try that for one of my customers. |
ok so where is your shop???? our local guys up here in glasgow are a wee bit funny bout things like that, there is one shop i use but its a bit of a bam/ned tunning shop lots of plastic crap chrome and stick on power gagues that dont connect to anything ( i only buy cleaning products there) so i dont know if the guys would know what there talking about my best bet is just to buy more RCA's and do it myself |
| Actually earthing to the battery is not such a good idea. Noise pick-up is due to voltage differences between "earth" at the amp, and "earth" at the head unit. In a perfect world you would connect both at exactly the same point, with zero length wire(!) Using the car chassis as a "virtual earth" works OK because the car is a big mass of metal, with minimal voltage drop. But the piece of wire between chassis and battery is likely to have some voltage drop, depending on current flow. So if the head unit is connected to one end of that wire (via car chassis) and the amp to the other end (directly to battery stud), you'll likely have worse noise pickup. I certainly suggest running the RCAs down the middle of the car, to try - or get new wires and try them. Just lay them through the interior of the car, don't bother installing them - and see if the noise issue is improved. Just experiment initially to find where the noise comes from, then tidy the install later. Another experiment is to temporarily run the head unit 0V with a thick wire from exactly the same point as the amp 0V/ground/earth - or even pick up a second wire from the 0V terminal on the amp. |
| whos good with ICE???? | aid | First Generation Interior & Ice | 2 | Apr 10th, 2007 09:11 PM |
| good in ice and snow?? | ksmgumbi | General Discussion | 10 | Jul 17th, 2005 03:48 AM |
| Max Power Ice manual, any good??? | Rayman | First Generation Interior & Ice | 3 | Sep 17th, 2004 02:45 AM |
| Dension ice > link : ipod / mikeythemini? | booda | First Generation Interior & Ice | 19 | Apr 30th, 2004 06:22 PM |
| Calling MikeytheMini! | Hat | First Generation Interior & Ice | 4 | Jul 12th, 2003 08:21 PM |
