| Does aftermarket sat nav work with heated windscreen? Just wondering if an aftermarket sat nav system works with heated windscreens? Don't have either myself to try but a friend had a Cooper S with heated windscreen and is considering buying a Garmin or TomTom sat nav, neiher has an external aerial as standard but there is mention that they have problems with screens that have heat reflective coatings or heated screens. Anyone any experience of this, would it recieve a signal through the glass sunroof or sidewindows? Don't know much about sat nav, obviously! |
| i have a mobile phone w/ tomtom installed, and an external BT (SIRF chipset) GPS receiver my actual car (which isnt a mini! its a vw polo actually) has an athermic reflective coating screen and the GPS receiver works fine but it takes a certain time (around 5 minutes, sometimes more.....until 10min) to catch the GPS signal i ll have my mini (w/ heated windscreen) tmrw, so i ll tell you then if its a problem or not |
| as promised, i tried my bluetooth gps receiver (Globalsat BT-338) w/ tomtom on my mobile phone in my mini with heated windscreen. I put the receiver just behind the windscreen and after a cold start, the GPS got the signal quite quickly, around 2min (even better than my old vm polo in the same condition, same way, same streets). i know that sounds pretty bad but there is lots of 4 to 6 stairs building, high trees and narrow streets where i started the test. then, i performed another cold test: i put the gps receiver in the center armrest and closed it. he found the gps signal in less than a minute (i didnt measure it but it was about 1 minute), this time i wasnt in the same condition: large streets and 2-3 stairs houses and a few trees. so dont worry an aftermarket satnav will work perfectly! |
| Sat Nav doesn't work in the cold | Bod | First Generation Faults & Fixes | 91 | Apr 1st, 2008 07:38 PM |
| Aftermarket Sat Nav | Blusox | First Generation Interior & Ice | 17 | Jan 11th, 2007 08:13 AM |
| (TomTom) GPS & Heated Windscreen - will it work | Hat | First Generation Interior & Ice | 14 | Dec 7th, 2004 09:58 AM |
| Aftermarket Head with Sat Nav??? Will it work??? | GeoffMM | First Generation Interior & Ice | 1 | Mar 7th, 2004 01:53 PM |
| Aftermarket Sat Nav Help please! | Pauline | First Generation Interior & Ice | 21 | Mar 4th, 2004 01:47 PM |
