retro fit cruise - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old May 31st, 2007, 12:20 PM
debicbr's Avatar
minifun
Local Time: 01:51 PM
United Kingdom Female View debicbr's Classified Ads
retro fit cruise
anyone seen the install instructions on here...
cant seem to find them.
Old Jun 3rd, 2007, 11:31 AM
chris.lamb's Avatar
Local Time: 02:51 PM
United Kingdom Male View chris.lamb's Chili Red & White 1st Gen MINI Cooper S Profile
debicdr,
drop me a private message with your email and I will send them to you.....
and anyone else who wnats them.
I have a copy of MINI EBA on CD.
Old Nov 24th, 2008, 04:56 PM
Retro fit Cruise Control
Chris,
Know it was some time ago now (2004) but you had some info on the requirement for retro fitting Cruise control to MC.
I have the Wheel Slip ring Airbag etc but believe I need a loom section and instructions.
any info greatly received
Old Nov 25th, 2008, 07:22 AM
chris.lamb's Avatar
Now available here :-
www.motoringfile.com/howto/MFSW.PDF
shows 2 spoke but 3 spoke is the same idea.
OK?
Old Nov 25th, 2008, 09:29 PM
scraggles's Avatar
United Kingdom Male View scraggles's Pure Silver & Body Color 1st Gen MINI One Profile View scraggles's Classified Ads
OK?
Motoringfile have had the instructions up for some time now. They're what I followed when I did mine - wouldn't like to do it again though.
The loom costs ~£20.
To fit the loom, the seats need to be removed, the inner sill covers, glove/oddments box driver and passenger side, the dash top, speedometer.
The loom connects to the fusebox in the left sill, the BCU in the right sill, the speedo, the new slip ring @£90 & a new brake switch @£25.
It feeds through the bulkhead to the DME control unit. The 40 pin DME connector needs all its wires removing and refitting one by one into a replacement plug which can accept the new loom - not a job for the feint hearted! The BCU then needs to be coded to enable the MFSW + Cruise control.
If you can find a dealer who will take it on; they'll quote 8 hours for the whole job, which at my local dealer rates comes to over £1000 labour - with £150 parts that's a total of £1200 not including the steering wheel!
It took me a couple of days to do and then got a dealer to code the computer.
Old Nov 27th, 2008, 07:11 AM
chris.lamb's Avatar
When I did mine I did not need to take out the seats but did need to remove the sill trim to get to the IBUS connector.
Also @ the engine ECU connector I just added in the 2 pins to the existing connector after drilling out the blanking plugs in the sockets, much easier than removing every connector.
IF you can buy the parts second hand and DIY then not an expensive mod, even the coding only cost my 1/4 hr labour @ Stratford MINI and got a free wash and vac.
Old Jan 20th, 2009, 02:12 PM
United-Kingdom Part numbers
Hi I have all the parts apart from wiring loom and brake switch. Has anyone got the part number so I can get them. Cant find them list anywere only as a kit thanks
Old Jan 20th, 2009, 03:49 PM
chris.lamb's Avatar
Brake switch?
Clutch switch I used a 61310300846 brake switch, fitted fine.
Harness, made my own.
Old Jan 20th, 2009, 04:55 PM
scraggles's Avatar
Here's the list of parts in the retrofit kit. In my case (2003 manual gbox), the Clutch module and clutch sensor plate were not needed. I think they're only relevant for very early cars. You probably also won't need the clips unless you're very unlucky removing the sill trims.
Code:
  1 x Slip Ring                    61316800997                                £90.00
  1 x Brake light switch    61316967601                                 £22.90
  1 x Clutch module         61319122702(/61316905900?)  £19.60
  1 x ClutchSensor plate 35316765622                                 £0.14
16 x clips                         51437048911                                   £3.57
  1 x Cableset                   61120136522                                 £15.80
  1 x Double connection  61138364566                                £0.71
25 x Cableties                61131367599
Old Jan 20th, 2009, 05:26 PM
United-Kingdom
Hi thanks very much thats great have fit a auto dim mirror that was easy thanks again
retro fit CC07ERS First Generation Interior & Ice 4 Sep 23rd, 2006 07:10 AM
Retro fit Cruise control???????????? BRGNICK First Generation Interior & Ice 4 May 12th, 2005 09:07 PM
H/K retro fit jgmini First Generation Interior & Ice 2 Jan 23rd, 2005 03:20 PM
H/K now available for retro fit!! masjj First Generation Interior & Ice 0 Jul 17th, 2003 07:14 PM
MFSW Retro-fit.......... Jock First Generation Interior & Ice 12 Sep 7th, 2002 05:48 AM
