Sat Nav Updates 2002 Cooper S - Page 3 - MINI Cooper Forum - MINI2 Mini Cooper Forums
  #31 (permalink)
Old Jul 22nd, 2007, 11:03 AM
Send a message via MSN to Meeerrrk
Local Time: 02:53 PM
United Kingdom Male View Meeerrrk's Dark Silver & Black 1st Gen MINI Cooper S Profile View Meeerrrk's Classified Ads
i had a CD based system in my 52 reg cooper s, tried an upgrade and it messed it up. Took me a good couple of days to learn how the system worked to find a fix for it. Got the upgrade loaded on in the end and got a map disk from ebay but didnt notice any changes...SO....
I got a mk4 DVD drive from ebay, havnt looked back since, its so much better. save your time and money and look for a DVD system.
Mark
  #32 (permalink)
Old Jul 22nd, 2007, 11:34 AM
DIY Help!!
Hi there,
I know I am not strictly a MINI user (though I often get one as a courtesy car!) but I have a major prob with my BMW e46 sat nav. I tried to go to version 2.91 with a download from the x5 website, everyone else seems to have it working fine. Mine doesn't
The disk was put into the dvd drive in the car, turned to ignition point 1, then....the system tries to read the disk...constantly and reboots....constantly.....nothing else happens!
And to top it all off the disk is stuck in the dvd drive...H E L P ! ! ! !
I think I made a big mistake by burning it onto a DVD r/w disk, fair enough but how to I get it out of the car??
Any help MUCH appreciated!!
thanks and Reagrds
Mark
  #33 (permalink)
Old Jul 22nd, 2007, 01:06 PM
DaFlake's Avatar
MMC Member
Local Time: 09:53 AM
Hold the eject button down for about 30 seconds and then press it trhee times. That should "hopefully" get the disk out. Then you can reburn 29-1 to another CD and try again.
You can get a good copy of V29 from Simply MINI
  #34 (permalink)
Old Jul 22nd, 2007, 07:13 PM
Nope...no joy..
Thanks for the advice, but I have tried holding the button down, hitting it many times, for anything from 30 seconds to nearly 10 mins. Also tried removing the fuses to cut the power but no joy at all.
I am going to have to take it to the dealer tomorrow, lord knows what that will cost...!
  #35 (permalink)
Old Jul 22nd, 2007, 07:56 PM
DaFlake's Avatar
MMC Member
Only other way that I know of is to manually remove it.
  #36 (permalink)
Old Jul 24th, 2007, 09:02 AM
freddiezb's Avatar
Cooper S
Sat Nav Still In The Dark
Hey Flakey,
I have downloaded the proper V26 file for the Mark 3 thats now on your site but still no joy, not sure if the sat nav is frazzled or it's simply not booting from the CD, i don't have a mode 1 or 2 option on my Mac software ( toast but i have tried burning from the iso and have just opened the disk up and burnt all the contents into a data CD - all at x1 speed - ill try that after work and see how i get on.
Quote: Originally Posted by DaFlake (original)
File is uploaded and much larger (as it should have been). I looked at the other disk that I had out there and it looks like only the MK4 stuff was on it. Sorry....
This is the full version. Lastly, make sure Mode1 is used and burn it slowly. Make sure you can access it with your computer. It may take a couple of min to boot in the NAV. Be patient.
  #37 (permalink)
Old Jul 24th, 2007, 09:51 AM
DaFlake's Avatar
MMC Member
I was looking around the Roxio forums and I don't see a way to make Toast Mode 1 or 2 selectable. Do you have access to someone with a Intel PC? I think that your problem is that the CD is in Mode 2 and the MK3 is choking on it.
For making disks of this nature I use Magic ISO.
  #38 (permalink)
Old Jul 30th, 2007, 10:43 AM
freddiezb's Avatar
Cooper S
Dear all,
Big thanks to Daflake & Mark ( Meeerrrk ) with advice and links regarding my sat nav - i have gone the whole hog and am now on the Mark IV DVD unit and it is so much better.
Thanks all for your help and comments.
Freddie
  #39 (permalink)
Old Jul 30th, 2007, 10:59 AM
DaFlake's Avatar
MMC Member
Quote: Originally Posted by freddiezb (original)
Dear all,
Freddie
, congrats! MK4 is a much better unit and the improved functionality is so worth it.
  #40 (permalink)
Old Nov 6th, 2010, 05:41 PM
Local Time: 01:53 PM
Hi where is the Sat Nav on an 03 COOPER S
I can't find the Sat Nav and need to reset it? Anyone got any ideas says its under passenger seat but not there?
Any ideas. I need to reset it as it is stuck, think where ever i am I m in Basingstoke!
  #41 (permalink)
Old Nov 6th, 2010, 10:56 PM
Just a tip don't double post, and you get a better response if you start your own thread rather than hijacking someone else's, I have answered your question on your other post.
  #42 (permalink)
Old Feb 13th, 2012, 01:29 PM
Sat nav no sound
Hi,
Can someone help me with a sat nav problem please,
I have a Garmin Zumo 550 which worked fine on my old Ford Focus,
I now have a mini cooper s 2002 I plugged the power lead into the cigar lighter and I got no sound, I checked both fuses and they are fine.
I was wondering if I need a special BMW adaptor.
  #43 (permalink)
Old Feb 13th, 2012, 01:37 PM
SneakinHysteria's Avatar
United Kingdom View SneakinHysteria's Classified Ads
Not quite the right thread as it is for the factory satnav on an MK1 MINI.
I can't see how the power adapter would determine if the Garmin's sound works or not. If it charges the unit then it's the right one. All 12v sockets are the same. They either work or not but won't switch your satnav to "mute". Do you expect the sound from the unit or via the radio/aux in?
I advise to check the satnav settings.
  #44 (permalink)
Old Feb 13th, 2012, 01:59 PM
Hi
Many thanks for your quick reply, the sound comes from the unit,.
I will check the satnav settings tonight,
Best regards,
  #45 (permalink)
Old Feb 20th, 2012, 07:46 PM
Sat nav problems
OK at long last I have found the problem,
It was a bad connection at the cigar lighter socket end, all is well now.
I must remember to put my posts in the correct thred next time.
Kind regards,
The scoundrel.
Tags: , ,
New 02 cooper S, can i have 3D sat nav?? cooper ste First Generation Interior & Ice 11 Dec 29th, 2007 04:49 PM
2002 built in sat nav Crystal First Generation Interior & Ice 3 Sep 3rd, 2007 03:37 PM
Aux on a Aug 2002 build car with boost and sat nav Hambroski First Generation Interior & Ice 4 Jul 24th, 2003 07:20 AM
Non Sat-Nav cars: Utilised Sat-Nav area WAY First Generation Interior & Ice 1 Nov 1st, 2002 02:46 AM
