| Be careful with Ebay as we have already seen users get scammed for money. These are not legal copies and should not be sold via Ebay. My advice to pay the money for the real copy or find a really good friend. Also make sure of what unit you have BEFORE buying. If you have a CD unit a DVD will not work (for obvious reasons). The latest firmware is 29-1 which I have on my site (Simply MINI). However, if you have an MK3 The latest version you will get is version 22 as this is the last update for that system. You can find what you have by going to the setup menu and posting here the numbers in the upper right corner. From that we can tell you what you need to do. |
| Sat Nav Updates 2002 Cooper S You people are stars!, much appreciated to all who replied, your help is appreciated!!. My sat nav reads: SW3-160 in the corner, pre-DVD drive i guess .Where can i get hold of firmware V.22 for this and will the Navteq 2007-2 maps i have seen available to buy work with my older drive?. Thanks guys for helping the newbie!! Cooper S and loving it!! |
| This link will give you all the information you need about the Nav Computer. BMW Navigation System FAQ - X5world You have the MK 3 nav computer ( the last CD Rom version ) and software version 16 ...although you already know this. That link also contains the firmware updates links too. Si |
| The drive that you have is an MK3 (non DVD version). So you will have to by map CDs, not DVDs. The firmware is most likely V 20.1 and you can run up to V23. So, there is some to be gained by updating. That being said, the MK3 is a bit picky on firmware. If you download the one from my site (Simply MINI), you can use it to get your system up to the V23 level (Even though it is a V29 disk, it does have the lastes release for the older system on it). When you burn the CD for install, make sure that you use mode 1 only as the older unit can't handle mode 2. |
| Sat Nav Updates 2002 Cooper S Thanks guys, this is much appreciated, only got the Mini last Saturday so a bit nervous with tinkering on firmware updates . once again a few more newbie questions for you to impart your knowledge on, what is mode 1 and 2!?..is this a selection that appears when the satnav starts after the update? or a method of burning the v29-1 iso file? , also will i need a KEY CD in order to upgrade to a newer OS?.Cheers dudes for pointing the way ![]() |
| Mode1 and Mode2 are methods of burning the ISO image in my zip file to the CD. Programs like NERO and MagicISO will let you select what mode you want to burn in. Older lasers have a hard time reading mode2. You might need the CD Key and we can get that with little problem. In fact, I will load that to my site tonight. The NAV update is pretty straight forward. You pop the CD in and turn the key to the first position. The system will automatically boot and update the firmware. I have seen issues with the MK3 not liking the newest release CD (V29-1) but it was easily corrected with an older CD. Also, be aware that if your CD does not boot afterwards it can be reloaded and stuck CDs can be gotten out. These are all things that people have experienced in the past. |
| Sat Nav Updates 2002 Cooper S You daman daflake!!, Thanks for sharing your knowledge dude!. Burnt the v29 iso in the correct way ( i am a Mac user but there was a helpful link on the X5 site ), still nervous about updating as have started reading some scary threads..is there just a v22 update available?. Will def bookmark your site and be checking. |
| Your defo going to need a CD key. Upgrading from either 15, 16 or 17 requires one but there is one on that link to down load. BTW I'm a Mac user and have burnt loads of images for BMW's Nav no problem. I'll check when I get home to see if I have V22.....I might have if I can find my discs I'll let you know Si |
| Thanks Dudes! BigLad & Daflake, You guys rock!, thanks for helping me with this, would like to hold out for V22..being a bit precious with the Mini at the moment and don't want to spend time trying to resolve a firmware corruption and flashing back etc..any copies of the V22 would be cool!. |
| Tags: cooper s, sat nav, updates |
| New 02 cooper S, can i have 3D sat nav?? | cooper ste | First Generation Interior & Ice | 11 | Dec 29th, 2007 04:49 PM |
| 2002 built in sat nav | Crystal | First Generation Interior & Ice | 3 | Sep 3rd, 2007 03:37 PM |
| Aux on a Aug 2002 build car with boost and sat nav | Hambroski | First Generation Interior & Ice | 4 | Jul 24th, 2003 07:20 AM |
| Non Sat-Nav cars: Utilised Sat-Nav area | WAY | First Generation Interior & Ice | 1 | Nov 1st, 2002 02:46 AM |
