| Finally got the Intravee from BimmerNav over Christmas and now have it fitted in my Mini. I am happy to say I'm very impressed. The interface and functionality is everything that I wanted. It really is easy to fit, sounds good and looks great on the Sat Nav Screen. however.... my listening experience is currently spoiled and I hope someone may be able to help. I used an in car electrics fitter to install the intravee along with some new speakers. I decided to replace the speakers because sound from the left front speaker would "drop out" at random times when listening to the CD's via the CD changer (the radio is ALWAYS fine and I no longer use cassettes!!). I figured that either the speakers or the CD changer was to blame so having new speakers and the Intravee replacing the CD changer would solve the problem. Unfortunately after fitting both, the sound still drops from the left speaker. It seems to happens about ten minutes into a journey and then cuts in and out at random times. Another issue has cropped up since the intravee has been fitted and this is what sounds like interference. Again it is only random but when it occurs it remains and sounds like a screeching noise over the music. Again the radio is not affected. Has anyone else experienced either problem. My fitter says all connections are good and thinks the problem lies within the head unit and suggests replacing it (possibly for one with a single CD). I have already spent loads on this project so would appreciate any help before spending out any more. Cheers Paul |
| I'd blame the CD Changer wiring loom, it sounds like the cable that carries the left hand audio signal has been snagged/crimped/damaged somehow when they guys did your installation. The loom normally carries left and right audio, along with signals from the head unit to change disc, play, etc. |
| It could be something to do with the wiring - but it all looks OK and sometimes works fine?? I've been reading up on this and its seems the HK Amp is known to be dodgy. The official part is very expensive so I'm looking on eBay etc. Does anyone know if the HK Amp for the BMW (part no. 65120690284003) will fit in the Mini? Cheers Paul |
| There's a MINI HK amp on eBay at the moment, it's in another HK thread on this Forum. No, the BMW amp is different IIRC, as the BMW has more speakers. But why would you fault find the amp, if it's only occuring with the CD changer, and the radio is fine? Surely that means the amp is fine too. I'd really have a close look at the CD Changer loom first before wasting money on an amp you might not need. |
| When thinking of changing your casette to your MP3 unit, keep in mind that not all factory cd head units built after facelift (2004) can play MP3s. I checked with two 07 plate cabrio owners and both said their cd players did not play MP3s but just normal cds. |
| Hi Geoff I didn't want the hassle of having to keep accessing the ipod to switch it on and change tracks etc. Also I would have to remove it every time I parked the car on the street. Also the sound through these adaptors is not that great. The intravee is great as everything is hidden away and all controls are accessed via the Sat Nav screen/buttons and MFSW controls. The speakers have been replaced with similar spec and were not cheap (£250). They do sound different but I could not say which sounded better? NEW QUESTION It seems my next task is to replace head unit. As I have a Harman Kardon Amp in the back do I need a special head unit in the front that does not have an amp incorporated. Or do they all work? Also the current stereo is an 03 Boost cassette unit. Can this be replaced with a CD unit after 04 which I understand can play MP3's. The MP3 option is not vital however. Cheers Paul |
| Tags: alpine, harmon kardon, ipod, mp3 |
| HELP.... Harman Kardon CRAPIEST stereo!!! | Nicooper | First Generation Interior & Ice | 14 | Jan 26th, 2005 12:00 PM |
| Is the Harman/Kardon option worth the price? | Freddo | First Generation Interior & Ice | 15 | Aug 15th, 2004 05:19 AM |
| Harman Kardon stereo upgrade | minigolf | First Generation Interior & Ice | 23 | Jul 11th, 2003 05:46 AM |
| Harman Kardon System - is it an option on the Cooper? | ken206 | First Generation Interior & Ice | 3 | Mar 20th, 2003 05:55 AM |
| Harman Kardon Stereo | rich kelly | First Generation Interior & Ice | 1 | Apr 28th, 2002 09:45 PM |
