Clock Removal - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Dec 20th, 2007, 06:33 PM
luVlee's Avatar
MINI2 Lover
Send a message via MSN to luVlee
Local Time: 04:51 AM
Canada Male
Canada Clock Removal
Hi, a year ago, i had a large ice chunk fall off a building and break through my sunroof sending glass everywhere. Since then, there's been a loud rattle from the ceiling where the clock is. When i press up on the clock, the rattle stops. So i'm guessing it's a piece of glass or a screw loose.
My question is, How do I remove the clock? (to remove whatever's in the ceiling). Do I just pry it out?
Old Dec 20th, 2007, 07:08 PM
Randall Raines's Avatar
MINI & other ½ both whine
Local Time: 11:51 AM
Try pulling it to-wards the rear of the car while trying to pull the front down, it should become loose at the front, however that may not work (it should, some seem to release easier than others), they have a metal spring clip on them at the rear (to-wards the rear of the car), re-fitting it, you hook the front in and push it up and it snaps into place if that helps you under stand a little better , make sure your hands are clean (you don't want a dirty roof-lining ).
The face-lift models with the map lights are the other way around, push it forward & the rear releases, they have a metal spring clip on them at the front (to-wards the front of the car).
Last edited by Randall Raines; Apr 21st, 2008 at 04:12 PM. Reason: Added face-lift info.
Tags: ,
My car has no clock! crofty136 First Generation Interior & Ice 5 Jun 5th, 2007 10:38 PM
Where's the clock gone?? It_works First Generation MINI Cooper S 13 Nov 29th, 2004 08:11 PM
clock removal ice First Generation Interior & Ice 2 Nov 6th, 2003 05:24 PM
