Sat nav shows North......when facing South??? Any ideas?? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 5th, 2008, 08:27 AM
Local Time: 10:06 PM
Question Sat nav shows North......when facing South??? Any ideas??
Firstly, Hi!
Brought my g/f a 2002 Cooper only a few days ago from an independant dealer and it soon became apparent that whilst driving in one direction, the sat nav showed me driving in the opposite direction!
I will obviously be revisiting the dealer, but wondered if this is a common problem and somethigni can sort myself? I've searched the forum and found loads of great stuff but nothing specific to this fault.
The car has the Mk3 version of the sat nav system SW 3-1/63 so will be looking fo the Mk 4 version but not in the immediate future.
Many thanks in advance
Russ
Old Jan 5th, 2008, 08:31 AM
steve11's Avatar
Mad Modder
Local Time: 08:06 AM
Australia Male View steve11's Electric Blue & Body Color 1st Gen MINI Cooper S Profile View steve11's Classified Ads
Ah, you have the Australian version meant for down under. I will take it off your hands & rid you of the problem.
Old Jan 5th, 2008, 09:33 AM
Oh Ok thanks Steve!
Old Jan 5th, 2008, 10:00 AM
KATENKEITH's Avatar
Challenge addict ...still
Local Time: 11:06 PM
England
Quote: Originally Posted by Russ n Vics (original)
Firstly, Hi!
Russ
It will only show direction of travel if you zoom down to 900 yds or less, otherwise the North arrow always points to the front of the car and the direction arrow on the map changes.
Hope this helps
K
Old Jan 5th, 2008, 10:02 AM
DaFlake's Avatar
MMC Member
Local Time: 06:06 PM
There are different views that you can select. One of them is that the map is always orientated with north to the top of the screen. This can be fixed selecting "map positioning" and then "travel direction".
Old Jan 5th, 2008, 10:04 AM
DaFlake's Avatar
MMC Member
Hope this helps
K
??? Never seen this on the MK3 or MK4... The OP definitely has an MK3 unless the 4 was retrofitted.
Old Jan 5th, 2008, 10:18 AM
Thanks for the comments so far. The car definitely has Mk3 SW3-1/63 and zooming doesnt help.
Just to add more detail:
The North indicator in the top left of the screen is pointing physically South even when vehicle is facing North (verified with Garmin hand held), i.e. Driving car actually North shows the vehicle travelling South on the map. Therefore when i left home last night to pick said g/f up from work, i left Portsmouth, travelled North up the A3M for 10 miles and the sat nav showed me as being just South of the Isle of Wight!!
It seems as though the compass may need reseting?!?
Any other ideas welcome folks.
Russ
Old Jan 5th, 2008, 10:27 AM
DaFlake's Avatar
MMC Member
Ahh, I misunderstood what you were saying.
If you go into the service screen (hidden) can you see if you are actually getting satellites? To get into the service screen, you need to go to the setup menu and then press and hold the "menu" button for about 5 to 10 seconds. Another menu should show up where you can view diagnostics.
I would check that. The MINI has wheel sensors that will move the map but without a satellite to give an accurate position, it would easily lose it's location and report it off. If that is the case, it is possible that the antenna is disconnected or needs to be replaced.
Old Jan 5th, 2008, 11:17 AM
KATENKEITH's Avatar
England
Thats on my X5.. thought they were the same system.....D`oh
Old Jan 5th, 2008, 11:24 AM
DaFlake's Avatar
MMC Member
They are..... MK3 or 4 depending on the year. Maybe I'm just not understanding what you are saying. No worries, I misinterpreted the OP as well.
Old Jan 5th, 2008, 07:27 PM
Sorry guys, i don't think anyone misenterpreted me, more likely that i didnt explain the issue very well!
I've gone into the hidden service menu and the GPS Tracking info page shows 8 visible satellites and in the GPS Status page is does not show any longtitude or latitude readings?!? Not sure if it should or not though.
DaFlake..............thanks for the very useful info so far but do you know if i should be seeing a longtitude or latitude reading with the car parked and in the diagnostic hidden menu?
Cheers Russ
Old Jan 5th, 2008, 07:40 PM
DaFlake's Avatar
MMC Member
Not sure on the MK3 but on my MK4 there is a lat long with 8 satellites. You might try a power cycle to see if that fixes it. (Disconnect and reconnect the battery)
Old Jan 5th, 2008, 07:47 PM
Ok. Just disconnect and reconnect or discharge system via earth leakage i.e. Connect + and - terminals of loom together to discharge capacitors?
Thanks Russ
Old Jan 5th, 2008, 07:48 PM
DaFlake's Avatar
MMC Member
Just disconnect and reconnect. This will force a reboot of the nav system.
  #15 (permalink)
Old Jan 5th, 2008, 08:00 PM
rkw
Local Time: 03:06 PM
United States View rkw's Pepper White & Black 1st Gen MINI Cooper Convertible Profile
Or pull/reinsert the fuse. I believe it is F22 for the navigation.
Tags: , ,
North/South Divide? Mini-Trainer UK & Ireland Discussion & Event Planning 19 Aug 29th, 2006 09:33 PM
Rear facing/Front facing Question (Paging Rakey) Spy Car MINIs, Children & Parents 3 Oct 21st, 2005 08:46 AM
North Vs South UK? StevePSB UK & Ireland Discussion & Event Planning 15 Nov 13th, 2003 12:49 PM
