» Sponsors
» Sponsors
Go Back   MINI2 - MINI Forum > MINI Technical Forums > MINI Interior & ICE > First Generation Interior & Ice
First Generation Interior & Ice First generation MINI interior 2001 - 2006
MINI2.com is the largest MINI Forum on the internet. Registered Users do not see the above ads.
Old Jan 10th, 2008, 06:16 PM
taylio
Local Time: 02:06 PM
Green Cooper CD changer fitment
hi, newbie here again, where in the boot do you fix a cd changer.
Old Jan 10th, 2008, 06:49 PM
United Kingdom Female View supa-dupa-cooper's Chili Red & White 2nd Gen MINI John Cooper Works Profile
Mine is fitted in the Boot
On the drivers side behind the plastic flap are the relevent plugs, they will need tucking down behind the plastic trim so they reach the bottom of the changer when its fitted (though they dont give you much to play with, so its a tight fit )
Is it a genuine MINI one you are fitting?
Old Jan 10th, 2008, 06:52 PM
MINIAC's Avatar
MINIAC
MINI Profiler
Local Time: 07:06 AM
United States Male View MINIAC's Dark Silver & White 1st Gen MINI Cooper S Profile View MINIAC's MINI Profile Images
From the Gallery of MiniMpi ...
Old Jan 10th, 2008, 06:54 PM
You have to put the seat down to do up the screws round the back too I ended up sat in the boot fitting mine
Old Jan 10th, 2008, 06:56 PM
taylio
Green Cooper
yes bmw, i located the plug and leads, so you just bolt it to the boot floor ?
Old Jan 10th, 2008, 06:58 PM
There are some little plugs in the plastic trim, take those out.
Fit the brackets to the CD changer.
Then the brackets line up with the ready drilled holes on the trim, so screw in place.
But you will need to plug it in on its side before turning it the right way up and screwing it in place
Old Jan 10th, 2008, 07:01 PM
taylio
are the 53 mcs the same as yours?, thanks 4 ur help. steve
Old Jan 10th, 2008, 07:02 PM
Should be the same..ive never looked in a Cooper S boot so wouldnt know. The only one I know is different is the convertible.
Old Jan 10th, 2008, 07:12 PM
airbusA346's Avatar
airbusA346
Confused By Certain Users
Quote: Originally Posted by MINIAC (original)
Is that genuine MINI or aftermarket?
Old Jan 10th, 2008, 07:15 PM
Looks genuine?
You have to be careful with aftermarket ones on later models
I tried to fit an Alpine changer with an interface but BMW changed something in the later models (05 on i think) which stops you doing it with most aftermarket ones
Old Jan 10th, 2008, 08:36 PM
MINIAC's Avatar
MINIAC
MINI Profiler
Here's one just like it with the MINI logo ...
CD Changer fitment Herbert Austin First Generation Interior & Ice 1 Aug 10th, 2007 01:03 PM
MP3 CD-Changer that will fit directly into a 'CD-changer prepped Cooper' ? ADO15 First Generation Interior & Ice 2 Jul 31st, 2003 12:44 PM
Fitment of the JCW kit GTT 280 First Generation MINI Cooper S 5 May 21st, 2003 03:22 AM
Fitment! DinkaDonka First Generation MINI Cooper 1 Jul 3rd, 2002 02:22 PM
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
