| Go to Diy and FAQ at top of MINI2.com above (Red Strip) and select Interior then How to fit OEM chrome line interior into a pre-2005 model ![]() The Modern MINI magazine method is less brutal but involves unscrewing part of the speedo surround:- March 2008 issue of Modern MINI magazine has a comprehensive step by step photo fitting guide by MiniMatt for the OEM interior chrome pack including dismantling the speedo and rev counter..........starting on page 42. |
| I doubt the screw will be a problem, eventually it may fall out on its own or you can remove the bottom steering column cowling to look if your that worried. Next time stick the screw to the screwdriver with a blob of grease or similar, or use a magnetic tipped screwdriver but even that won't always work with a stainless steel screw as they are often non-magnetic! |
| Hello all, first post for me. I have been lurking and learning. I too can't figure out how to remove the speedo bezel and I could not find the above mentioned DIY by Paul Mullet. Can anyone provide the actual link or point me better in the correct direction? Thanks, Bill |
| Of course, I did not offer all the necessary information ... I have a 2nd gen Mini, not the first. It seems all the instructions are for the first gen. I sent Modern Mini an email about how to go about ordering a back issue since it doesn't seem to be addressed on their website, being in the US it may be problematic getting my hands on the March 2008 issue dealing with this topic. |
| I just fitted the chromeline interior to mine too! Great looking mod! I didnt have any probs with the centre ring but I got the nav. The ring just unclipped right off for me. There was a clip at the bottom of the ring. If you look it should be there. Dont take my word for it though as its prob slightly different. Some seem to get it off easily whereas others have to fiddle around. Dont worry about losing a screw! I lost 1 when I done mine! Ooops! I read the warnings but it was the smallest of slips then next thing... GONE! I might remove the bottom part of the column cover cause it annoys me knowing its there as it wont take long to pop it off and back on again |
| Thanks SportDan, I wish the process were so easy for the gen 2 MINIs, the rings are attached to the black dash pieces and the whole mount has to come off. I can't figure out how to remove the trim to get to the mounting screws that hold the whole assembly on. |
| R56 2nd Gen Fitting Guide for Chromeline Interior here may help:- http://home.cogeco.ca/~djdnz/Chrome%...20How%20To.pdf Another 1st Gen Chrome fitting Guide here:- JW's MINI: '05 Chrome Interior Install |
| Wow! Jackpot! Exactly what I was looking for and more! I can't thank you enough for this ... and since I am never satisfied, I don't suppose you replaced all your R56 speakers and photo'd that process too??? Sheesh, this is one hard car to work on! |
| Mab01uk: Thanks again so much, I just removed the speedo bezel, your instructions were perfect. I would never have guessed the location of the top two screws. |
| Tags: chrome, convertible |
| chrome door inserts - screw covers | ##~James~## | First Generation Interior & Ice | 2 | May 15th, 2007 10:00 AM |
| Removing chrome speedo | MarkW19 | General Discussion | 4 | Jul 2nd, 2006 07:05 PM |
| Chrome speedo ring help please? | Scylla | First Generation Interior & Ice | 0 | Oct 26th, 2004 05:57 PM |
| Cheap chrome speedo surround | LANER | First Generation Interior & Ice | 10 | Jul 29th, 2002 11:08 AM |
