2003 Sat Nav Disk/Software - Speed Cameras - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jul 29th, 2008, 02:28 PM
bobnobski's Avatar
MINI2 Irritant
Local Time: 11:46 PM
England View bobnobski's Dark Silver & Body Color 1st Gen MINI Cooper S Profile View bobnobski's Classified Ads
Ok - got a 2003 - 53 MCS with factory Nav. Notice that this system doesnt show speed cameras - Can you simply use the latest DVD disk - 2007/8 and will this automatically upgrade to Nav to show safety cameras.
Is it a simple proceedure to upgrade the maps - ie just wack in the dvd and go - or is it more complicated that this.
Cheers for you help!!
Old Jul 29th, 2008, 03:45 PM
DaFlake's Avatar
MMC Member
Local Time: 06:46 PM
It is more complicated. The map disks by default do not have the camera locations on them and you have to manually add them. I used a program called Pimp My Nav to do it the last time but you can also look through the sticky at the top of this forum to try and do it yourself.
Camera POI can be gotten here...
Become a Member of PocketGPSWorld.com
You have to be a member to get them.
Good luck!
Old Jul 29th, 2008, 06:34 PM
United Kingdom View bensidewalker's Classified Ads
It's worth noting that you can do it yourself (rather than using Pimp My Nav which costs $30 I think) but it is quite complicated - see X5world forums for more info...
Old Jul 29th, 2008, 06:58 PM
DaFlake's Avatar
MMC Member
Just be advised that it is a pain in the butt and changes from disk version to disk version.
We also have it posted here...
http://www.mini2.com/forum/interior-...avigation.html
Old Jul 30th, 2008, 11:11 AM
bobnobski's Avatar
MINI2 Irritant
Just checked - mine has the DVD version - currently using 2003 didsk - what extra would the 2007/8 disk give me if i swicthed over
Old Jul 30th, 2008, 11:57 AM
I think just updated maps...I have 2008-02 disc and the only difference I've noticed so far is that when you're taking an exit off a motorway/A road etc it tell you to 'take the next exit, number bla bla' (before it just said take the next exit)
Old Jul 30th, 2008, 12:42 PM
DaFlake's Avatar
MMC Member
Updated POIs
Updated Roads
Updated TMC channels
That is pretty much it. The 2003 is pretty out of date and many new roads will probably be on the disk.
Old Nov 4th, 2008, 06:55 PM
I too have a 2003 - 53 MCS with factory Nav. I would bei ntrested in what you decided to do and if you were successful in obtaining a DISC with updated roads, speed camara`s and POIs.
How do I find out the correct disc for my MCS
thanks for any help
Old Nov 4th, 2008, 07:14 PM
DaFlake's Avatar
MMC Member
First, go to the setup menu on your nav screen and post the numbers in the upper right corner in full.
Once you do that, we can determine if you have a MK3 or 4. If you have an MK3 you need to buy the high CD from BMW, if it is a DVD unit, you can buy the High DVD from them.
Once you get the updated disk, you can make your own disk to add POI. However, this will only work with the DVD, not the CD as there is not enough space.
Old Nov 4th, 2008, 08:16 PM
Ok done that
no is SW 4- 1/20
Does this info help ?
Old Nov 4th, 2008, 09:13 PM
DaFlake's Avatar
MMC Member
You have a DVD model...
With that, you firmware is V22 or V22.1 and the latest is V31.
The latest firmware is on my site Simply MINI and it is located on the left side. You simply download it, unzip it and burn the ISO file to a CD.
Pop that into your NAV with the key in first position. Wait and it will update the NAV OS. This will get you better routing and a perspective mode.
As for the disk you can buy from BMW or Navteq and the current version is 2008-2 at 149.00 pounds. Once you get that, you can start the process of adding POI to it but you do need to be a bit of a computer nerd. If you aren't there are some tools you can buy that will help like...
Pimp-My-Nav Home
Old Nov 5th, 2008, 07:48 AM
Thank you for your help.
As a new mini2 member I had a little difficulty in finding your reply.
I need to learn to navigate the site before trying to improve the sat nav. Any tips.
If I upgrade the OS with your V31 download will I see an improvement in routing and a perspective mode with out purchasing version 2008-2 or is this a ridiculous question ?
Old Nov 5th, 2008, 12:28 PM
DaFlake's Avatar
MMC Member
No ridiculous at all. Yes, you will see improved routing and perspective with the older maps.
As for the site, no problem at all. We all have to learn sometime.
Old Nov 6th, 2008, 08:11 AM
Smile
OK I have downloaded the V31 from your web site
I have power achiver 2000 on my computer.
when opening this it contains a file called
NavigationV31.nrg
Is this the OS file you refer to that I need to burn to a CD ?
  #15 (permalink)
Old Nov 6th, 2008, 09:36 AM
ALD0's Avatar
iF IT'S nrg FILE, SHOULD BURN IN nERO IF YOU HAVE INSTALLED?
Tags: , , , , , ,
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/first-generation-interior-ice/160437-2003-sat-nav-disk-software-speed-cameras.html
Posted By For Type Date
Sat nav - forum talks | BoardReader This thread Refback Nov 15th, 2008 05:32 AM
Speed Cameras on R56 Sat Nav robdjones Second Generation Interior & Ice 19 Feb 8th, 2012 09:43 PM
Sat Nav disk angharad Second Generation Interior & Ice 3 Dec 25th, 2007 07:31 AM
