HELP - Installing a subwoofer with a boost radio - Page 2 - MINI Cooper Forum - MINI2 Mini Cooper Forums
  #16 (permalink)
Old Aug 31st, 2008, 10:42 PM
blarthdaderni's Avatar
Local Time: 12:56 PM
Northern Ireland
if you fit a clean sweep to the speaker lines and then run the connected RCA's into an amp then you can run a normal sub no problem!
active subs are usually rubbish (there are a few exceptions) so i'd definately recommend at least one 10" or 12" sub!
if you go over to the TalkAudio forums and join up, they'll be able to go into more detail for ya!
good luck getting it sorted mate!
  #17 (permalink)
Old Sep 1st, 2008, 05:38 PM
exactmax
United Kingdom Male View exactmax's Classified Ads
Thanks for information concerning using a 'clean sweep' connection but I think that the easiest method for me will be using a RCA adapter from Mikey...
Any chance you could point me in the right direction for the RCA Plug & Play from Mikey place and will it effect using the Plug & Play adaptor I have for the aux lead?
Where is a good place to run the live cable from the battery to the boot?
Many Thanks
  #18 (permalink)
Old Sep 1st, 2008, 06:46 PM
Northern Ireland
a clean sweep basically is an RCA adapter and it allows you to connect to a normal rca input on an amp.
the adapter you're thinking of can only connect to an active sub with a high level input which, unless you're planning to spend about £500 is probably going to be inferior to a similar amp and sub setup of the same price!
  #19 (permalink)
Old Sep 1st, 2008, 08:01 PM
aussie11's Avatar
Local Time: 11:56 AM
United Kingdom Male View aussie11's Classified Ads
I have got a 10' sub in my Mini, but have aftermarket headunit. hope you get it in soon
  #20 (permalink)
Old Sep 2nd, 2008, 07:39 PM
exactmax
Hello Aussie11,
What make sub do you have in your mini as I am finding numerous subwoofers are too large to fit into the Mini boot.
Do you have any idea ideas where is the best place to run the powercable from the battery to the boot and do you know any good aftermarket fitters in London?
Many Thanks
  #21 (permalink)
Old Sep 2nd, 2008, 08:20 PM
aussie11's Avatar
Hi, I have a Rockford Fosgate P2 10' sub. The power cable runs from the battery along the the top of the engine bay under the black grills into the bulkhead and down the drivers side.
A link to my build
http://www.mini2.com/forum/interior-...t-install.html
  #22 (permalink)
Old Sep 2nd, 2008, 08:23 PM
Snowie's Avatar
Local Time: 01:56 PM
England Male View Snowie's Thunder Blue & Silver 1st Gen MINI Cooper S JCW GP Profile
Quote: Originally Posted by exactmax (original)
Hello Aussie11,
Many Thanks
If you have an S then the battery is in the boot - what is the issue??
In Italy
  #23 (permalink)
Old Sep 2nd, 2008, 08:24 PM
aussie11's Avatar
Quote: Originally Posted by Snowie (original)
If you have an S then the battery is in the boot - what bis the issue??
Nice and easy then
  #24 (permalink)
Old Sep 2nd, 2008, 08:36 PM
exactmax
Thanks for your link Aussie - very helpful I now realise that the battery is situated in the boot so that makes it very easy to fit a subwoofer (just fitted a sub for my girlfriend in a VW Beetle and took ages!!! hopefully not as long to do in my mini)...
Whats the bass line like on the Rockford sub - I am after something with kick and doesn't fill the boot .
Thanks for everyones help so far, this is such an informative website and is a real assest to anyone that owns a Mini - there is nothing like this out there for other cars
Max
  #25 (permalink)
Old Sep 2nd, 2008, 08:39 PM
aussie11's Avatar
It is very good nice and tight, I have always used Rockford their products are very good
Where in London are you? I am in Rochester to to far from the big smoke
  #26 (permalink)
Old Sep 2nd, 2008, 08:45 PM
exactmax
I'm based in Richmond, Surrey to very close to the centre of London... Do you know anyother makes of subwoofers that would be good to look into?
I have been recommended Vibe and Inphase - any comments on those manufactuers? Whats the pros and cons of having a amp & sub or just an all in one job (amp built into sub)?
Many Thanks
  #27 (permalink)
Old Sep 2nd, 2008, 09:00 PM
aussie11's Avatar
What sort of money are you looking at take a look at Talk Audio they help me out. also have a look at the link to this site
Car Audio Direct for car stereo, navigation and audiovisual electronics.
  #28 (permalink)
Old Sep 2nd, 2008, 09:03 PM
exactmax
Well I am looking at around the £150-200 mark for the sub so nothing too special, just something that will put a 'pump in my trunk' . Had a look at Talk Audio but this forum is being more informative at the moment
  #29 (permalink)
Old Sep 3rd, 2008, 11:07 AM
aussie11's Avatar
For that money you can get a good sub, I paid around £120 for my one. Some other makes I looked at were DLS, Rainbow and Diamond
  #30 (permalink)
Old Sep 3rd, 2008, 08:27 PM
exactmax
Does anyone know if the Vibe CBR 10" EVO Active subwoofer fits into the mini cooper s boot? I've just been out to my car and measured up and its very very close fit so not sure if it will actually fit.... Any one got one of these fitted in theirs?
Many Thanks
Tags: , , , , , , , ,
R55 Subwoofer install - Wiring on BOOST radio? W2k Second Generation Interior & Ice 8 Jun 13th, 2008 05:10 AM
connecting subwoofer to the mini boost system slimindustries Second Generation Interior & Ice 8 Apr 13th, 2008 12:23 AM
Installing Subwoofer with Harman Kardon scottp7 First Generation Interior & Ice 2 Jun 21st, 2006 06:30 PM
Add subwoofer to stock Boost Headunit fj0 First Generation Interior & Ice 7 Dec 21st, 2004 09:35 AM
Installing Powered Subwoofer 1st Mini First Generation Interior & Ice 11 May 3rd, 2003 12:07 AM
