Mini Sat Nav Screen - Page 2 - MINI Cooper Forum - MINI2 Mini Cooper Forums
  #16 (permalink)
Old Feb 24th, 2009, 03:09 PM
nikos1890's Avatar
nikos
Local Time: 01:57 PM
Greece Male View nikos1890's Dark Silver & White 1st Gen MINI Cooper S Profile
..chris i went over to the parts shop for the screen but unfortunately it is not in good condition cause the dimmer button and round button close to menu button are missing.So if you ever hear anything about a screen over there,plaese let me know.
Thanks again....
  #17 (permalink)
Old May 19th, 2009, 08:08 PM
nikos1890's Avatar
nikos
Chris
I finally received the screen i was telling you about in my e-mails.This guy probably forgot to send it on time and the package took 40 days from Grermany to Greece!!I got it from e-bay and the screen is the ALPINE TME-M770S 6,5 touchscreen monitor.
I can tell you that the screen fits perfectly on the cover of the cluster.
With surprise i noticed that the actual display is sharp ,probably the same model with the oem display but with a touch panel on top of the display for touch screen operation
ID:	157055   Click image for larger version
ID:	157056   Click image for larger version
  #18 (permalink)
Old May 19th, 2009, 08:15 PM
nikos1890's Avatar
nikos
...the only problem is that i have to remove the circuit of the power and volume button in order to fit the screen in the navigation cluster.
I will try tommorow in a car audio store, to power and operate the screen without this circuit to see if it is working.
If not,i think i will have to extend the cable tape of the screen with longer cables and hide(?) the power button in the glovebox.
Another problem is that the circuit board of the screen wont fit behind the screen in the metal bracket you send me together with the nav cover.
So i will leave the board as it is which is right on top of the screen and then glue the entire display with the board on top of the navi cover.
Right now if you just leave the screen on top of the cover it locks in place!
The cover has small lips of the four corners and together with the menu button and the other ''button'' that used to accomodate the power on lamp,it forms a small step for the display to lock on.
Below i have the pictures of the power and volume circuit ,the ''lock'' of the screen on top of the cover and the no fitting of the board in the metal bracket.
ID:	157058   Click image for larger version
ID:	157059   Click image for larger version
ID:	157060   Click image for larger version
ID:	157061   Click image for larger version
  #19 (permalink)
Old May 19th, 2009, 09:25 PM
nikos1890's Avatar
nikos
a picture of the Alpine Headrest 6,5 touchscreen monitor TME-M770S before and after ''operation''......
Let's hope everything will work all together at the end.
I just remembered i have to go to the dealer for the coding of the cluster.......
ID:	157065   Click image for larger version
ID:	157066   Click image for larger version
  #20 (permalink)
Old May 21st, 2009, 04:49 PM
nikos1890's Avatar
nikos
..so i have tried to power the screen without this small circiut board but with no luck.A technician from Alpine told me that i can operate the power button simpy by putting two extension cable leading to another push button far from the circuit board.
So i did just that.You can see at the pics.Now i can hide the power circuit board behind the display and use the extented red push button that i placed in the centre on navigation cover where the oem round button used to be....
...do you think i should paint this black....?
ID:	157081   Click image for larger version
ID:	157082   Click image for larger version
  #21 (permalink)
Old May 22nd, 2009, 06:39 AM
Local Time: 12:57 PM
United Kingdom Male View Porn_Star's Classified Ads
WoW great work. Yes black gets my vote
  #22 (permalink)
Old Nov 18th, 2009, 02:56 PM
nikos1890's Avatar
nikos
....last pictures showing double sided glue tape holding the screen with the plastic cover....
On the next post you will see a video of the screen fit in the dash and working..!!
ID:	158676   Click image for larger version
  #23 (permalink)
Old Aug 20th, 2010, 12:00 PM
chris.lamb's Avatar
United Kingdom Male View chris.lamb's Chili Red & White 1st Gen MINI Cooper S Profile
Any more on this NIKO?
Tags: ,
Screen Protector for Sat Nav TonyFoy Maintenance & MINI Care 2 Jul 25th, 2008 05:40 PM
Help Needed, Just retro fitted oem sat nav into my mrs mini but screen dont turn on. a4r0 First Generation Interior & Ice 13 Aug 24th, 2007 10:44 AM
I want sat nav screen!! ombler First Generation Interior & Ice 10 Jul 20th, 2006 03:02 PM
Sat Nav Screen gone white? Dan1979 First Generation Faults & Fixes 0 May 24th, 2006 07:51 PM
Mini Lcd sat nav screen! Blackaeromini First Generation Interior & Ice 6 Feb 1st, 2005 05:14 AM
