| Actually.... this thread should answer your question... http://www.mini2.com/forum/interior-...placement.html |
| You can see here the exploded diagram for the door lock and pin..... RealOEM.COM * BMW R53 Cooper S DOOR HANDLE FRONT/LOCK, SINGLE PARTS I think you're going to have remove the door card and take a closer look. Perhaps you can remove the pin from the top of the rod, and glue your new one in place? |
| If you mean door pin as in the thing that pops up and down when you lock/unlock the car, then its quite easy to get off. I had to change a door lockonce so had to remove that pin. Its quite fiddly and a torch would be helpful. Basically you need to unscrew the door card Torx screws, and prize the door card off (carefully starting from around the bottom.) Once thats off peer inside the door towards the lock mechanism, and the rod going up to door pin should be visible. It attaches to the back of the lock mechanism. To remove it from the lock, you simply push the rod towards the outer skin of the door (away from the lock), and it pops out. The whole rod/pin can then be removed through the door cavity. I assume you can then glue the new pin onto the rod/pin assembly. I actually had some photos of inside the door but deleted them from my computer yesterday - typical! |
| OK. Had a look at them and I have not seen the mini aftermarket door pin but also presume they are shapped or that the bar is moved when the new pin goes on. I put some plyers around them and it broke off, the best way would be to heat the pin and remove it or just continue to break the parts as I did you will need to remove the door card first |
| Tags: door pins panels |
| Door lock pins | erb777 | First Generation Interior & Ice | 0 | Sep 2nd, 2008 07:36 AM |
| Faulty Door Pins? | djwoody | First Generation Faults & Fixes | 5 | May 16th, 2008 09:14 PM |
| Door pins | cooperJCW | First Generation Interior & Ice | 4 | Dec 21st, 2006 01:05 PM |
| Just Fitted My 'S' Door Pins :-) | zanhar25 | First Generation Interior & Ice | 8 | Dec 21st, 2006 12:54 PM |
| Aluminium door pins... (door lock buttons) | GTT 280 | First Generation Interior & Ice | 3 | Jan 12th, 2003 06:31 AM |
