Igor has qustion on factory fitted alarm - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Oct 8th, 2002, 08:50 AM
Local Time: 11:58 AM
England
Igors alarm does not autolock.
Igor has question, If left alone with no one in mini, should factory fitted alarm lock itself ?
Igor
The Bells
The Bells
Old Oct 8th, 2002, 09:14 AM
lightbody's Avatar
Send a message via ICQ to lightbody Send a message via MSN to lightbody Send a message via Yahoo to lightbody
Scotland Male View lightbody's Chili Red & Black 1st Gen MINI Cooper Profile
No it shouldn't.
Would cause havoc for me - I'd be locking the keys in all the time!
Rob Lightbody - http://www.roblightbody.com
2004 Red/Black Cooper replaced a 2001 BRG/White Cooper
Old Oct 8th, 2002, 09:36 AM
dcfkan's Avatar
In exile, down SOUTH!
Local Time: 12:58 PM
United Kingdom Female View dcfkan's Chili Red & Lime Green 1st Gen MINI Cooper Profile
I too am not in favour of auto-locking alarm - for fear that Mr DK would leave the car keys in the boot, walks off, then forget about them (I never do that of course!)
DK
Old Oct 8th, 2002, 02:32 PM
BrantV's Avatar
Local Time: 03:58 AM
United States View BrantV's Hyper Blue & White 1st Gen MINI Cooper S Profile
I agree with not auto locking if the doors had been opened. However, what if You exit the car, set the alarm, and then walk away. If while the keys are in your pocket, the unlock button accidentally gets pressed, wouldn't it be nice if the car automatically locked itself after 30 seconds? The delay should be settable.
Since the doors remain closed, it should be nearly impossible to lock your keys inside the car, unless you were inside the car when you set the alarm. There's also the chance that you had a window or sunroof open only far enough to drop the keys into the car after you locked it. Big enough to slip the keys through, but too small to get your hand through. Very small chance. If that happens, reach into your wallet, and use your spare plastic key.
It's too frequent an occurrence, where car alarms get accidentally turned off as the button gets pressed while in a pocket or purse. My first car with an alarm had a tendency to go off frequently, until I discovered that sometimes when I sat down, the crease in my jeans wold set the alarm off. The press and hold panic feature was enabled by default.
Having the car automatically lock itself if you don't open a door, likely because you didn't intend to enter the vehicle, would be a nice touch.
Also, on the subject of locking keys inside vehicles. What happens if you open the door, and then lock everything manually, without the remote, and then close the door. It should unlock the door. Does it stay locked if you hold the handle? Since the remote is standard, perhaps it shouldn't. And is it smart enough to prevent you from closing a locked door when the keys in the ignition.
Wish Igor would return from the stone age to the present.
Old Oct 8th, 2002, 02:44 PM
smiffy's Avatar
Send a message via MSN to smiffy
Wales View smiffy's Dark Silver & Body Color 1st Gen MINI Cooper S Profile
Smiffy wants to know: why does the alarm turn off when the central locking remote is pressed to open, but doesnt turn the alarm off when opening the car with the spare key in the lock
S for Smiffy
"Kids in the front seat cause accidents, accidents in the backseat cause kids!"
Old Oct 8th, 2002, 02:53 PM
potts's Avatar
Send a message via ICQ to potts
Smiffy,
Using the spare, you have 30 seconds to turn on the ignition, which will then turn off the alarm. But yeah, just opening the door with the spare ought to turn it off.
Old Oct 8th, 2002, 02:55 PM
smiffy's Avatar
Originally posted by potts
Smiffy,
You have 30 seconds to turn on the ignition, which will then turn off the alarm. But yeah, just opening the door with the spare ought to disarm it.
Ta, it takes me about 30 seconds to get the Autolock steering lock off
S for Smiffy
Old Oct 8th, 2002, 03:15 PM
Dom's Avatar
Dom
Test thread infiltrator
Send a message via MSN to Dom
England View Dom's British Racing Green & White 1st Gen MINI Cooper Profile
Try pushing the drivers door pin down with the door open - it shouldn't work, thus meaning you can't accidentally lean on it and lock it or something. Not sure if it's the same with the passenger side.
Dom
Old Oct 8th, 2002, 03:32 PM
BrantV's Avatar
I think it has to do with the identification chip embedded inside the key, and the fact that only the ignition switch has a sensor to validate the key. I believe you can just pass the key next to the ignition. I'm not sure you have to actually tun the key.
Anybody could steal a wax impression of your key, and make a duplicate to gain entry. Only the actual key should allow them to drive it off, and apparently disable the alarm.
Also, if the lock can be picked, would you want some lever in the door lock that when pulled, turned off the alarm? Doesn't sound very secure.
Old Oct 8th, 2002, 05:20 PM
potts's Avatar
Yeah, I'm aware of the I.D. chip in the key. My thinking was the drivers door could have the validation sensor. Though having it in the ignition is more secure.
If only the buggers would give us 2 remote keys...
Old Oct 9th, 2002, 08:02 AM
England
Igor says thank you all for your help.
The Bells
The Bells
Old Oct 9th, 2002, 08:46 AM
dsc68's Avatar
Local Time: 09:58 PM
Australia Male View dsc68's Chili Red & White 1st Gen MINI Cooper S Profile
Alarm and steering lock
Tough neighbourhood then
Dean
MCS CR/W with bonnet stripes, DSC, full leather, MPSW, alarm. trip computer, X-Lites
Superduperminicooperexpertengineering
Old Oct 9th, 2002, 10:48 AM
Martin L's Avatar
MINI defector
England Male View Martin L's Astro Black & Body Color 2nd Gen MINI Cooper Profile
Autolocking is good if the manufacturer actually has brains.
My golf for instance used to automatically re-lock itself if after been unlocked and nobody actually open the doors. This is to protect against accidently unlocking the car
I had a terrible exerience earlier this year while on holiday with an autolocking Jeep. While at a filling station I left the keys in the ignition as my brother was still in the car, he decided to use the bathroom so left the car while I was still filling it up. The dumb ass car decided to lock itself with the keys still in the ignition
We were on the way back to Frisco to catch our flight home so you can image the panic
Luckily we were in Sacremento so a locksmith turned up within half an hour of calling roadside assistance. Thank God Jeeps have cr@p security as the lock was popped open in seconds
After this experience in answer to your question Igor, I think they shouldn't
MINI, RX8 and MX5 - Done those............. It's now TTime
Unofficial MINI2.com bean counter
Factory Fitted Alarm / Immoboliser FunFindus First Generation MINI Cooper S 2 May 31st, 2007 09:38 AM
Factory Alarm rokcrln First Generation Interior & Ice 9 Jun 10th, 2004 06:43 PM
Factory Alarm or After Market Alarm? prs General Discussion 5 May 7th, 2003 01:31 AM
Factory Alarm spod General Discussion 45 May 2nd, 2003 03:48 AM
Please help on my new factory alarm dinlo First Generation Interior & Ice 5 Apr 9th, 2003 04:49 AM
