changing steering wheel - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Dec 22nd, 2008, 10:59 PM
Local Time: 03:33 AM
im thinking about changing my current steering wheel to the jcw 3 spoke wheel, is it hard to do or would i need to get someone to do it if so how much?
thanks
Old Dec 23rd, 2008, 07:05 AM
r1_kde's Avatar
JCW 210 apparently not!
Local Time: 04:33 AM
United Kingdom View r1_kde's Classified Ads
Not hard,
ensure your wheels and steering is strait.
disconnect the battery so the air bag is safe, take a t25 driver and feel foe a hole about 10 oclock and 2 oclock about 10mm behind the air bag, they look like dimples and may need a small cut with a sharp knife. as you push the t25 in you will feel a spring, once depressed pull that side of the air bag forward, do the same on the other side. on the back of the air bag lift the tabs connecting the wires and remove, place in the passengers well. undo the 15-20mm bolt and remove the wheel, if you have the mfsw undo the screws from behind and pull off including wires. now the wheel is loose pull forward and ensure you do not turn anything whilst doing that. take the new wheel and put in the same location as before.
put everything back in the reverse order.
Labour is less than 1 hour but expect 1 hour so normal garage £40 - £50 (above the M25) BMW £100 (above M25)
Old Dec 23rd, 2008, 12:48 PM
Mini Cooper 2003, 1.6 CVT
I was thinking of doing this too, is it possible to put the JCW wheel on when the previous one was a standard 2 spoke?
Old Dec 23rd, 2008, 03:54 PM
c.gray2008's Avatar
United Kingdom View c.gray2008's Indi Blue & Body Color 1st Gen MINI One Profile View c.gray2008's Classified Ads
i am just about to do this to mine, an issue of modern mini gives you a step by step, its quite straight forward, most the electrical clicks apparently clip straight back into the new wheels.
One question i have is does anyone know if the new R56 3 spoke airbag will fit the earlier R53 three spoke wheel?
cheers.
Old Dec 24th, 2008, 03:58 AM
Bonnie Scotland's Avatar
R53 Turbo!
Local Time: 02:33 AM
Scotland Male View Bonnie Scotland's Astro Black & Body Color 1st Gen MINI Cooper S Profile View Bonnie Scotland's Classified Ads
I have a 3 spoke steering wheel for sale from a June 06 JCW Cooper S if anyone is interested.
Sorry, can't help with the removal
For all your Scottish and MINI needs
http://www.newminiscotland.co.uk/forums
Old Dec 28th, 2008, 10:16 AM
Rakey's Avatar
Total MINI dot com!!
United Kingdom Male View Rakey's Classified Ads
I've posted up a how to do this with pictures
http://www.mini2.com/forum/2nd-gen-i...ing-wheel.html
Old Dec 28th, 2008, 07:51 PM
rkw
Local Time: 08:33 PM
United States View rkw's Pepper White & Black 1st Gen MINI Cooper Convertible Profile
Swapping the steering wheel itself is easy, but there are additional steps and expense for multifunction steering wheel controls. A very nice writeup here:
http://web.mac.com/jonnieoh/My_MINI_...el_How-To.html
Nice writeup for an R56, but this is a 1st gen forum.
No, does not fit.
Old Dec 29th, 2008, 10:20 AM
Rakey's Avatar
Pretty much the same as R56 apart from the release of the airbag unit is a bit more tricky with there being no hole to simply push and release
Just pull airbag at top and try to release the pins that way is how I did my R53
changing steering wheel jaynlisa08 First Generation Faults & Fixes 5 May 22nd, 2008 07:43 PM
changing to a multi function steering wheel Black Pearl First Generation Interior & Ice 12 Jan 5th, 2008 10:20 PM
Changing The Bulbs In The 3 Point Stereo Control Steering Wheel jcw 60 First Generation Interior & Ice 3 Aug 24th, 2007 11:59 AM
changing the steering wheel saknibs First Generation Interior & Ice 7 Mar 17th, 2006 01:59 AM
airbag light after changing steering wheel jampies-cooperS First Generation Faults & Fixes 5 Dec 12th, 2005 08:54 PM
