How to remove a cd/radio - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 22nd, 2009, 04:12 PM
Local Time: 11:58 AM
Wales
Wales How to remove a cd/radio
Hi All
How do i remove a radio as i'm replacing it with a cd/radio player? Is ther any step by step instructions on the removel,i alredy have the fixing kit to install.It's an 04 convertible
Old Jan 22nd, 2009, 05:01 PM
mikeythemini's Avatar
Local Time: 12:58 PM
Check the DIY section at NewMINIStuff.com
Old Jan 22nd, 2009, 06:12 PM
Send a message via MSN to +++MadMatt+++
United Kingdom Male View +++MadMatt+++'s Classified Ads
I have a pioneer cd unit fitted, and would like to change for new head unit, is the removal process the same as if removing the factory, or is there a shortcut?
Old Jan 22nd, 2009, 06:43 PM
mini33's Avatar
Perfectionist Cooper S
United Kingdom Female View mini33's Classified Ads
When my bruv has done mine more than once he curses as it a lot of screw undoing, at lest i know its not easy to nick
Cant remember the exact order but gives you a rough idea
You have to undo & remove the pilars either side of stereo
Remove the stereo plate etc
I seem to remeber you have to undo the to screw on the dash by th speedo but that only bit i am not 100% off
Then once you have undo all the screws you should be able to remove the old one
Not sure about wiring etc as mine was already changed from standard when i bought
Hope that gives u a guide
Good luck
Old Jan 22nd, 2009, 07:15 PM
I will have a look at it, if it looks like im gonna balls it up, il get some pro to do it for me I think! Thanks!
Old Jan 22nd, 2009, 07:23 PM
Much easier if an aftermarket stereo is fitted
Just insert the pioneer removal keys into the slots & pull it out, then unclip the cahe & replace with the new cage
Old Jan 22nd, 2009, 07:27 PM
Are all removal keys the same? Caus the pioneer was in there when i bought it.
Old Jan 22nd, 2009, 08:08 PM
No but most are log thin strips of metal
Old Jan 22nd, 2009, 09:52 PM
richcoopS's Avatar
Now with added boost...
United Kingdom Male View richcoopS's Classified Ads
It'll take five minutes as Mikey says.
Remove the plastic clip-on surround that frames the head unit, then insert removal keys (long thing bits of metal about half an inch wide) down the middle of the sides and pull out. Remove the head unit cage and you're ready for the next one. Make sure you keep the wiring adaptor for the new head unit.
I had mine out and back in in no time this weekend fitting a MFSW adaptor from Mikey
Indi Blue R53 MCS 233 bhp & 200 lb-ft
Project Rory Read my Project Thread View my Garage
can any1 tell me how to remove radio mini mucker First Generation Interior & Ice 6 Nov 20th, 2009 02:54 PM
Are there manuals for the R56 Boost Radio & DAB Radio to download JohnWB Second Generation Interior & Ice 2 Mar 6th, 2007 09:02 AM
Satellite Radio and HD Radio MINIAC Second Generation Interior & Ice 3 Dec 1st, 2006 08:40 AM
Can american radio on a cd player be changed to UK radio greeny010586 First Generation Interior & Ice 6 Sep 15th, 2006 06:19 AM
How to remove the standard radio boost system ? badboyzbadboyz First Generation Interior & Ice 2 Mar 17th, 2004 10:57 PM
