Retrofit Airconditioning on 2005 Cooper S - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Mar 30th, 2009, 04:27 PM
Local Time: 06:52 PM
Malta
Hi All,
I have just purchased a 2005 Cooper S and would like to Retro Fit Air Conditioning... Does anyone have an idea of how to go about this or has anyone gone through this already??
Any help would be greatly appreciated!!
Old Mar 30th, 2009, 05:50 PM
lee-swindon's Avatar
Local Time: 05:52 PM
United Kingdom View lee-swindon's Dark Silver & Black 1st Gen MINI Cooper S Profile View lee-swindon's Classified Ads
i can imagine it being alot of hassle!!
Old Mar 30th, 2009, 08:37 PM
Local Time: 04:52 PM
Does it have no air con at all or do you mean you want to upgrade to climate?
Retrofitting air-con will be a big job. You'll need piping, rad, pumps, controls...etc.
Old Mar 30th, 2009, 11:16 PM
mab01uk's Avatar
A couple of people have done this on here, I have collected all the s/h parts and a wiring harness to retro-fit but have not had the time recently to remove my whole dash to fit yet. Quite a big job but dash comes out as a complete assembly and is detailed quite well in the Bentley Mini manual. You need to like a bit of a challenge..............
Heres more in Link below plus a BMW MINI pdf instructions download for the Air Con retrofit kit.
Retrofitting Auto Air Conditioning Guide - Mini Torque
Some more info here:-
http://www.mini2.com/forum/interior-...rol-panel.html
Post no.2 here has some pics of the dash assy removed and air con/heater assembly:-
http://www.mini2.com/forum/faults-fi...t-working.html
Old Apr 1st, 2009, 04:22 PM
Malta
Thanks for the advice! will have a look! i think i need to fit in everything since it has no A/C at all so have no idea what i'm gonna find (or going in for!!)
more info will be appreciated!!
thanks again!
Old Apr 1st, 2009, 04:59 PM
Malta
By the way am looking to retrofit normal A/C not the automatic one...probably cheaper and hopefully less complicated!!
Old Apr 1st, 2009, 07:46 PM
mab01uk's Avatar
All the parts you need are listed in the post links/pdf above. The basic heater unit has to be replaced with the very similar air-con unit which has the evaporator rad as well as the standard heater martix fitted.
The automatic climate air con is a different unit and more complicated but is the only system BMW seem to do the retrofit add on wiring harness for as far as I know, I too would prefer to fit the less complicated manual air con. but you would need to work out the basic wiring, etc, from a scrap donor Mini perhaps? Both systems require your BC1 programming/coding by a main dealer or fitting the BC1 from a donor Mini with A/C.
Old Apr 7th, 2009, 04:35 PM
Malta
cheers thanks... If you do come across any PDFs for manual A/C it would be great!!
thanks!
Old Apr 8th, 2009, 02:45 PM
chris.lamb's Avatar
United Kingdom Male View chris.lamb's Chili Red & White 1st Gen MINI Cooper S Profile
Had a look, not an option.
Old Apr 10th, 2009, 05:13 PM
Send a message via AIM to IrishCooper Send a message via MSN to IrishCooper Send a message via Yahoo to IrishCooper
Local Time: 11:52 AM
Ireland
Your 05 didnt come with A/C? i have never seen that in 4 years of MINIs
Mykl Milligan
'06 HB/W MCS Sport & Premuim, LSD
'05 DS/W MCS Works (Dad's Car)
Old Apr 10th, 2009, 06:42 PM
mab01uk's Avatar
Auto and Manual A/C on UK MINI's was only fitted as an optional extra until this year, when manual A/C became standard and Auto/Climate an upgrade option.
2005 tranny with LSD retrofit question... DarkMiniCooperS First Generation MINI Tuning 6 Aug 24th, 2006 08:35 PM
Airconditioning stephanie First Generation MINI One 6 May 26th, 2005 07:41 PM
2005 Locking Glove Box retrofit? azimmerm First Generation Interior & Ice 14 May 3rd, 2005 04:12 PM
Retrofit Alarm on 2005 Mini slipped_disc General Discussion 0 Mar 2nd, 2005 02:53 PM
airconditioning? Fdlove91101 First Generation Faults & Fixes 1 Jul 6th, 2004 12:49 AM
