Hoi Folks,
I've discovered a great and very cheap
mod to get the passenger window to auto-up with just a single short flick of the switch.
It involves adding a 22 microfarad capacitor and a 100 Ohm resistor to the toggle switchpanel or the wiring that goes to the toggle switchpanel. These cost about 10 cents each at your local electronic-parts shop.
What it does is letting the Main Computer (BC1) think that the switch is still pressed for about 6 seconds which is enough to close the passenger window fully.
The capacitor and te resistor are connected in series. They then are connected parallel to the switch.
On foto 1 you see the switch panel that's removed from the car (you have to remove the downtubes first).
Foto 2 shows how to open the back of the switchpanel by unlocking 6 locking tabs (3 on each side pictured in the green circles)
Foto 3 shows where to connect the capacitor and the resistor.
The capacitor is polarity sesnitive and the - (minus) has to be connected to the ground plane (either directly or via the resistor) the resistor is not polarity sensitive and can be connected either way.
I used the via's on the circuitbaord to connect the components. The capacitor (plus) is connected to the lower of 2 via's shown in the picture. The - of the capacitor is connected to the resistor and the other side of the resistor is connected to the via of the ground plane.
