| Auto v Manual Air Con. I started with a Cooper with Auto Air Con and now have an MCS with manual. I reckon that manual is far better! The auto air con was difficult to switch off and was confusing in cold weather - should I leave it on at say 20 degrees or switch it off completely. If you switch it off controlling a manual heating system with a digital temperature switch is not ideal. |
| OK, here's what I've figured out (not in the manual btw) about the Auto Temp Controls. If you turn the fan off, you still have the temp regulated....air still passes through when you're driving at a decent speed. If you turn it off (where the display goes away) then I've noticed that the temp coming out of the vents is a constant temp...it doesn't auto adjust...so if it was putting out a bit warmer air to get the cabin temp up..then it will stay at that temp. In the summer, when I wanted to have NO AC at all...i set the temp to the lowest temp, then turned it off. Hope that helps! |
| I have only just ordered my MINI, so I haven't been able to test that properly, let alone compare it with the automatic. My reasoning for going for the manual air-conditioning was my intended use. I promised myself last summer that my next car would have air-conditioning. As a rule, I don't like to have air-conditioning on for long periods, so I imagine that I'll just use it for quick blasts of cold air on the hottest of summer days. I'm hoping that it will do something to cool the car down when the car's been parked in the sun for a while. |
| Just because the indicator light for the aircon is on when auto is selected doesn't mean it's running. I've noticed that mine only cycles when the ambient air isn't cool enough to bring the temprature down to the selected level. Another thing that I've noticed that if I select auto, then press the aircon button, the aircon light goes out and the system stays in auto mode. Seems right by me mate! |
| Sunroof? Worth it if I have manual air-con already? | Toby | General Discussion | 32 | Aug 16th, 2010 10:48 AM |
| Manual Air Con Pics | Hannibales | Second Generation Interior & Ice | 7 | Nov 19th, 2006 07:52 PM |
| Automatic air-con 'v' manual? | miniwilly | First Generation Interior & Ice | 10 | Aug 9th, 2004 08:46 AM |
| Air con manual/auto | silver_mini | First Generation Interior & Ice | 1 | Jul 25th, 2004 11:00 PM |
| Air-Con / Auto Air-Con / Climate control ??? | fitzsimonss | First Generation MINI One | 13 | Apr 19th, 2004 09:44 PM |
