| help please with Harman/Kardon system hi i have a 2003 mini coopers with uprated Harman/Kardon system on it been really good but 2 days ago there was a crackling in the passanger side front speaker even when i turned the head unit of it was still there then when i came to the car the next day only the twiters are working nothing from the other speakers we have head harman/kardon amp out of the back of the boot behind the right hand side panel and there is no fuse in it just a block connecter if we disconnect the amp none of the speakers work at all plus it back in then the twiters start working so now i am at a loss so does any one have any ideas thanks |
| Sadly, a number of H/K amplifiers have failed, especially earlier ones like your '03. On www.NorthAmericanMotoring.com recently someone claimed to have found a company that could repair it; don't know if the repair was successful. |
| You do not need to replace the HU, since when disconnected from the H/K amp it's a standard Boost unit. Of course it has no RCA outputs, so you might want an aftermarket amp for that reason. The speakers are quite special to the H/K amp - for example there's no crossovers for the door speaker "woofer" and "mid/tweeter combo" (it's internal to the amp); and the rear speakers are dual voice coil. You would really be planning on replacing all the speakers, if you put in an aftermarket amp. Be prepared for it to be louder, but have less clarity (unless you go to a very high end audio shop). |
| I definetly recommend that you speak to Mikey at NewMINIStuff.com and see what your options are. He can help you get an idea of what you will need to do. GBMINI is right (I just didn't want to use the wrong terminology) on the system. It is pretty much and all or none system outside of the HU. |
| Or speak to Mikey at NewMINIStuff.com and see what he says |
| I'll be looking on ebay for sure. A replacement from BMW is £472.51. I've tried a few breakers but they all say that the unit is sort after and rare.... not looking good for grabbing a bargain! |
| I've had to bite the bullet and buy a new amplifier from BMW, £390 from Cotswold BMW (20% discount)!!! I bought a used one on ebay "guaranteed working", and guess what..... it was the same as my old one. I've tried to find a repairer, BMW apparently haven't released any service info or spares so the electronic specialists can't do anything with them. |
| Harman Kardon System again ... | spod | First Generation Interior & Ice | 29 | Sep 11th, 2003 11:45 PM |
| harman/kardon system value. | warren33 | First Generation Interior & Ice | 54 | Jun 18th, 2003 04:36 PM |
| Harman Kardon System - is it an option on the Cooper? | ken206 | First Generation Interior & Ice | 3 | Mar 20th, 2003 05:55 AM |
| Harman / Kardon System | ICEman | First Generation Interior & Ice | 71 | Jul 11th, 2002 06:09 AM |
| Harman Kardon system - worth it? | normalizer | First Generation Interior & Ice | 10 | Feb 15th, 2002 12:28 PM |
