back rest swap - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jun 27th, 2009, 02:20 PM
Local Time: 09:50 PM
back rest swap
hello guys
i have been offered some leather seats for my 02 cooper s
the seats that are on offer are from a convertible cooper and i have been told that the back rest bit on the convertible wont fit due to the roll bar thing?
is this correct? or is it possible to change just the COVERS and not use the rear frame?
also if there is no way possible then does anyone have the opposit problem and would like a swap?
Old Jun 27th, 2009, 05:31 PM
Paul's Avatar
MINI2 No.1
Local Time: 08:50 PM
England Male
Rear seats are a completely different shape and size.
Old Jun 28th, 2009, 08:14 AM
scraggles's Avatar
United Kingdom Male View scraggles's Pure Silver & Body Color 1st Gen MINI One Profile View scraggles's Classified Ads
I've done this and fitted/bodged sidewalk cabrio seats into onto normal seat frames.
The back rest covers are smaller than standard due to the space taken up by the roof mechanism. The covers can just about stretch over the standard frames - it was difficult. The cabrio has extra bits such as a leather strap and an extra catch mechanism for locking the seats when the hood is down. You'll either have to keep these or repair the holes. The cabrio headrests are built into the roll hoops so they're no use to you. You'll need to re-use your existing head rests, which you'll need to cut new holes in the covers and the foam pads so they fit to the backs. I was lucky and found matching headrests on eBay for a fiver.
The seat base is also wider and has a different frame fitting. It can be swapped onto the standard frame but it will overhang and still be too wide for the narrower car body. - I put some stitches in it to tuck the extra width. I also applied felt to the edges which come into contact with the interior plastics to stop all the squeaks the leather made by rubbing where it wasn't designed to fit.
In short, it can only sort of be done and only worth it if they're cheap.
Back to front wheel swap hoojkel Wheels, Tyres & Brakes 12 Jan 17th, 2008 09:51 AM
Where can i get an arm rest that slides back so i can put the hand brake on .Boyracer. First Generation Interior & Ice 5 Oct 7th, 2005 10:43 PM
How about an arm rest like this? averyocooper First Generation Interior & Ice 3 Apr 28th, 2004 12:31 AM
I finally found a back rest for the Mini that works! Kraigster414 First Generation Works 3 Apr 19th, 2004 07:13 AM
Arm Rest Simon Jackson First Generation Interior & Ice 44 Sep 27th, 2002 01:55 PM
