Help! Heating isn't working and engine fan is going beserk! - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Nov 10th, 2009, 12:14 PM
Local Time: 01:00 PM
I've got a R52 Mini Cooper and the heating was working fine until the weathers started to get colder! Now it takes an age to warm up and clear my steamed up windscreen, etc. Also yesterday my car was sat in the cold for around 7hours then I drove it for around 4 miles in traffic, by the time I'd arrived at my destination the heating was slightly warm and when I got out of the car the engine fan was on and going beserk.
Is there something wrong with my thermostat? The dial displays my car as being warm (dial is in the middle).
Any help, recommendations, welcome.
Cheers in advance
Old Nov 10th, 2009, 12:58 PM
Local Time: 12:00 PM
United Kingdom View Donz's Hyper Blue & White 1st Gen MINI Cooper Profile
have you checked your coolent level?
Old Nov 10th, 2009, 03:44 PM
adam_Randell's Avatar
Send a message via MSN to adam_Randell
United Kingdom Male View adam_Randell's Pepper White & Black 2nd Gen MINI Cooper Profile View adam_Randell's Classified Ads
^^ echo Donz
your heating is an auxiliary to your coolant (not exactly sure how it works) but hence it takes a while to warm up i.e. while your engine warms up
Old Nov 10th, 2009, 04:48 PM
minimattsback's Avatar
Going up in the world
It may have an air lock in the heating system and may need bleeding...What way is your fan going berserk!!!!
Old Nov 10th, 2009, 05:47 PM
Cheers for all the replies.
I checked the coolant when I got in my car to drive home and it was really low, so as I only had a bottle of water in the car, I stuck a bit of that in it. Then whilst driving home the temp gauge raced up to top and the red light came on, then it dropped to 3/4 then I stopped shortly afterwards and the fan was going beserk/making a right racket!
Gonna go check on it in 5 mins when it's had time to cool down. Never had any bother with this up until now, is it a common thing or common for this time of year?
Old Nov 10th, 2009, 08:10 PM
MINI One Seven
United Kingdom Male View M.O.S's Pepper White & Body Color 1st Gen MINI One Profile
Is it auto ac or normal?
The Original MINI One Seven
Yorkshire MINI Register - PM for details
Old Nov 10th, 2009, 08:42 PM
Not sure what you mean, it's got ac but i've not used that since July.
The coolant tank when I went to check on it at around 7pm was still full of the water I'd put in but the engine was still warm after my short journey home from work. I'm gonna check the coolant in the morning to see if it's still in the same position. Just hoping I don't have to pay a visit to the local mini garage
Old Nov 10th, 2009, 10:09 PM
MINI One Seven
is it climate control (digital display) or the standard a/c - 3 turny knob things?
Old Nov 11th, 2009, 12:52 AM
DaFlake's Avatar
MMC Member
Local Time: 08:00 AM
A couple of things that could be a problem but first, I recommend that you get it checked ASAP and not drive it all around. If your car overheats, it could cause serious problems.
1. Could be a bad thermostat.
2. Could be a failing fan assembly. (guessed due to the "racket" it was making).
3. Could be a leak in another area and your car was overheating
4. Could be a combination of things.
As you can see, it is all a guess. I highly recommend you get the car in to be looked at.
Old Nov 11th, 2009, 04:26 PM
Cheers for all the info, I've decided to book it into a BMW garage (not a chain one!) to have a look at it, I'd rather be safe than sorry!
Old Jan 12th, 2012, 07:53 PM
Scotland
How did u get on with your heating?
Old Jan 19th, 2012, 07:52 PM
it could be due to the resistor blowing it controls the fan, the engine fan has 2 speeds if the resistor blows the fan goes onto full speed it then makes a noise like a helicopter.
Low Speed Fan Resistor - we need solution - North American Motoring
this is an old thread the info might be still be useful
Heating not working... PickledOnion2 First Generation Faults & Fixes 4 Nov 13th, 2009 07:14 PM
Heating on and off, Fan on overrun and no coolant left? MiniMellie First Generation Faults & Fixes 2 Jan 16th, 2009 06:46 PM
Heating intermittent/ rad fan runs on MikeB First Generation Faults & Fixes 3 Dec 10th, 2008 05:06 PM
heating fan failure! aladin5 First Generation Faults & Fixes 12 Oct 21st, 2006 06:51 PM
Cooling Engine Fan Not WOrking eekthemeek First Generation Faults & Fixes 5 Aug 23rd, 2005 08:01 PM
