Why poor quality?(setup problems - aftermarket speakers with stock audio system) - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Oct 27th, 2002, 01:23 PM
DinkaDonka's Avatar
MINI 2 OLD BOY
Local Time: 01:00 PM
Why poor quality?
I have bought some 6x9's (Kenwood) and a Pioneer amp , 2 x 150w , although the speakers are loud the sound quality is very poor and the max out quite early , if any1 could tell me as to why this is happening or hoew to fix it , it would be most helpful.
Cheers,
Paul
Old Oct 27th, 2002, 01:25 PM
Dom's Avatar
Dom
Test thread infiltrator
Send a message via MSN to Dom
England View Dom's British Racing Green & White 1st Gen MINI Cooper Profile
are the gain settings ok? To set these, have your headunit at 75% and increase the gain until distortion, then turn it down slightly.
What headunit are you using, how is it connected to the amp?
Dom
Old Oct 27th, 2002, 04:00 PM
DinkaDonka's Avatar
MINI 2 OLD BOY
Hey
Im running a Sony head unit the MD one with the flip down panel , not sure how its conected tho but i shall try ur idea , thanks very much,
Paul
Old Oct 27th, 2002, 04:18 PM
Dom's Avatar
Dom
That might help, depending on what your problem is... who installed it?
Dom
Old Oct 27th, 2002, 04:43 PM
CurtP's Avatar
Local Time: 07:00 AM
United States View CurtP's Pepper White & Black 1st Gen MINI Cooper S Profile View CurtP's Classified Ads
Re: Why poor quality?
Originally posted by DinkaDonka
I have bought some 6x9's (Kenwood) and a Pioneer amp ... the sound quality is very poor and they max out quite early
Sorry to say, but the answer as to why is in your own post.
Old Oct 27th, 2002, 09:26 PM
Local Time: 12:00 PM
@CurtP... He is partially right... check all your connections. if that doesnt work (or even if it does) than follow Doms advice, your gain shouldn't be over half way on any higher end amp. If all else fails resort to the voltometer, you should still have an instruction manual that came with your amp, it should have output levels for all the poles on the amp. confirm that they are all at appropriate levels (I have hade many faulty amps that caused similar problems). if so then it is time to take it to the people you had instal it and give them a swift boot to the head!
"Surely someone must be running this monkey show"
Old Oct 29th, 2002, 12:27 PM
DinkaDonka's Avatar
MINI 2 OLD BOY
Yes!
Cheers every1 . i have done a bit of fiddlin and have resolved the problem.
Thanks again,
Paul
Kappa Speakers better than H/K setup jfelix First Generation Interior & Ice 10 Mar 13th, 2005 03:13 PM
Stock audio system. luVlee First Generation Interior & Ice 9 Jun 5th, 2004 02:53 PM
audio gurus - questions about setup pesos First Generation Interior & Ice 0 Jul 19th, 2003 06:58 AM
New Audio System: Speakers JonBoyWalton First Generation Interior & Ice 0 Apr 18th, 2003 05:03 AM
Help on audio setup. kidtexas First Generation Interior & Ice 2 Aug 27th, 2002 05:28 PM
