| Sorry for sounding dumb, I've checked and the only wires going into the back of the head unit are as follows (I've written down the label on the wires and the colours, i dont know what is needed, they seem to match to me. Can I just remove the illumination / dash light or will this stop the backlight on the unit working?? Sony Head Unit > ISO cable 1 2 3 4 +12v constant - yellow 5 power antenna - blue 6 amp turn on +12v - blue/white 7 +12v ignition switched - red 8 chassis ground 12v- - black These match the following cables on the MINI head unit harness adapter 1 2 3 4 +12v constant - yellow 5 left rear +ve - blue 6 illumination / dash light - orange 7 ignition / switched 12v+ - red 8 chassis ground 12v- - black I'm a bit confused. I don't want to wire something the wrong way in case things go bang |
| Chris is correct. It seems strange the Sony has so few connections, how does it know when you switch the lights on so it can dim the display. Also look for a white wire in your Mini's original wiring, this is for the amp of the aerial. You can connect the amp turn on blue/white to this. It seems a common problem with these ISO convertors that they miss out the aerial amp connection. ![]() Some people are like a Slinky ........ not really good for anything, but you still can't help but smile when you shove them down the stairs |
| Thanks for the help so far. I ordered a new 16pin cable as I was getting nothing with the old one (no power at all, nothing). Now I have the new one, only the main unit has power, the flip down fascia has no power and no display. The buttons do nothing, but the main unit is happy to accept and eject CDs Any ideas? I should have just stayed with my original MINI unit |
| Tags: dashboard, head, lights, radio, unit |
| boot pops open when lights turned off | Muttzcuttz | First Generation Faults & Fixes | 20 | May 6th, 2011 01:14 PM |
| Dashboard lights Have come on, Please help! | minibbb | First Generation Faults & Fixes | 9 | Aug 30th, 2006 08:39 AM |
| Dashboard lights... | Mattia | First Generation Faults & Fixes | 6 | Dec 18th, 2003 12:25 PM |
| HELP! Radio removal - dashboard built like Fort Knox! | gazzaman28 | First Generation Interior & Ice | 26 | Nov 16th, 2002 10:39 AM |
| Radio turned off during ful right lock turn | JonathanK | First Generation Faults & Fixes | 3 | Aug 28th, 2002 02:55 PM |
