cold air only from my heater? - MINI Cooper Forum
First Generation Interior & Ice
post #1 of 4 (permalink) Old Mar 24th, 2010, 10:52 AM Thread Starter
Local Time: 05:48 PM
United-Kingdom cold air only from my heater?
Can anyone help? I have a 2003 bmw mini cooper s. When I turn the heater on I only get cold air? The car temperature gauge only goes to half way as it as always done when the car heater was working fine.
Any help or advive would be appreciated.
The only thing I have done to the car lately is change the blown cigaret lighter fuse.
firemansam is offline
post #2 of 4 (permalink) Old Mar 24th, 2010, 11:54 PM
SteveM3's Avatar
Local Time: 04:48 PM
Quoted: 15 Post(s)
The standard heater or basic heater/air con uses a cable to change the temperature so this may be broken. The automatic climate control used electric motors. It makes desicions to operate these based on inputs from various sensors. A sensor may be faulty or the control module could be faulty. As far as I am aware all BMW's override sensors when you select the maximum possible heat so try that as a test.
SteveM3 is offline
post #3 of 4 (permalink) Old Mar 31st, 2010, 08:53 AM Thread Starter
Thanks Steve,
It's a 2003 mini cooper s with air con. The heater contraol is circular with an lcd display in the middle.
My wife, who's car it is, admits to possibly disconecting or braking something in the drivers side footwell. I have looked in that area and can see a plastic arm like mechanism hanging down. (It has a yellow dot on it) I do not have a maual to see where or if this should be connected in any way but perhaps you might be able to tell me.
Many thanks for ay help. Martin
post #4 of 4 (permalink) Old Mar 31st, 2010, 08:58 AM Thread Starter
Steve,
just been corrected by the wife,,,her car has automatic climate control.. whoops!
will try the max heat test.
Went to BMW mini yesterday who said they think it's a sensor or solenoid,, located in dash. £450 to remove dash and replace!!!!!!!!!!!!
Told my wife to buy a thick coat!!
Martin
Which cold air intake? slvrsoho First Generation MINI Cooper 5 Sep 28th, 2013 01:16 PM
Dave.F or Alta Cold Air Intake?? Mini-Mc First Generation MINI Tuning 10 Jan 31st, 2013 01:21 AM
cold air intake feed best location location carterleeds1 First Generation MINI One 0 Dec 29th, 2012 12:03 AM
Cold air 2012 clubman? Minicoopcoop Second Generation MINI Tuning 2 Sep 24th, 2012 06:46 PM
Can cold air intakes damage the engine? tarayislandgirl General Discussion 3 Aug 18th, 2012 11:28 AM
