Passenger Seat Will not slide back. - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 21st, 2010, 07:42 AM
Local Time: 06:01 AM
I purchased a 2004 Mini Cooper in August of 2010. The passenger side seat is now stuck in the forward sliding position. The recliner and the up and down on the seat still work but my seat will not slide backwards. I look under the seat the the clip that grabs the track is stuck.
Has anyone else had an issue with seats doing this? If so please advise.
CooperMichaels
Old Sep 21st, 2010, 10:16 AM
minicore's Avatar
Super Moderator
Online
Local Time: 01:01 PM
United Kingdom Male View minicore's Chili Red & Body Color 2nd Gen MINI John Cooper Works Profile
Hello and welcome, the problem you mention is discussed in the following two threads:
http://www.mini2.com/forum/first-gen...ront-seat.html
http://www.mini2.com/forum/first-gen...ent-fault.html
Hope that helps.
Old Sep 28th, 2010, 11:11 PM
Hope that helps.
Its unbelievable how how much people are being charged for this, as the cable isn't listed as a separate part you have to buy complete runners, I fixed mine by getting some bike bowden brake cable from my odds box which is the same stuff and made a new one by soldering the old ends and central ball onto the new cable... cost nill and works fine also i found part 11 from the rear seat as i had an old one lying about www.bmminiparts.com - Diagram View has almost the same end fitting one side just needs a little bending and filing
Old Sep 29th, 2010, 05:52 PM
chris.lamb's Avatar
United Kingdom Male View chris.lamb's Chili Red & White 1st Gen MINI Cooper S Profile
11 01/04/2001 04/05/2005 7051159 bowden cable 2
11 01/09/2002 n/a 7160591 bowden cable 2 7051159
Passenger seat stuck in a reclined back position 85NIXMIN Australia 12 Aug 24th, 2010 07:23 AM
Passenger Seat Not Sliding All The Way Back Cosmo1111 General Discussion 1 Jun 27th, 2008 01:53 PM
Seat Problem - Tilt No Slide Tad First Generation Faults & Fixes 0 Feb 14th, 2007 05:44 PM
Passenger seat won't slide! Carcass First Generation Faults & Fixes 7 Jan 24th, 2006 05:47 PM
Passenger seat too far back/stuck!!! Carcass First Generation Faults & Fixes 3 Jun 21st, 2005 12:44 PM
