Front Speakers Not Working - HELP!! - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 18th, 2011, 03:37 PM
Local Time: 12:36 PM
Hi Guys,
I have a 2004 R50 Mini Cooper. I blew the front drivers side speaker so I bought a 2nd hand replacement on eBay which only cost £15 - thought it wern't too bad!
Anyway, so I took the door panel off etc and replaced the speaker, turns out the speaker I bought was worse than the one I blew - No bass comes out of the speaker.
So to make sure it was the speaker that was the problem, I took of the left door panel and tried out the passenger side speaker into the drivers side... worked perfectly. So I put the good speaker back into the passenger side where it originally came from and now it does not seem to work either!
The only explanation I think is that the back of the speaker is magnetic, and a few times when I was installing it it did hit the door which caused it to magnet together. Can this damage the speaker???
Any help or recommendation will be grateful as I am stuck to bits!!
Peter
Old Sep 18th, 2011, 03:44 PM
Not normally, put a AA battery to it see if it makes a noise
Old Sep 18th, 2011, 03:48 PM
Just tried it now... nothing.
I don't know if its the speaker of the adapter that plugs into the speaker
Peter
Old Sep 18th, 2011, 03:53 PM
Put it back on the drivers side again and try, to eliminate the plug..
Old Sep 18th, 2011, 03:55 PM
tried that at least 4 times.... same thing
Peter
Old Sep 18th, 2011, 04:11 PM
Oh well, looks like two front speakers may be needed, are there any soldered joints that have come away, its strange not to have any noise.. PS test resistance of the speaker with a multimeter if you have one
Old Sep 18th, 2011, 04:20 PM
It doesn't look like there are any sooldered joints anywhere, there is noise coming out from the speakers but just about. There is no bass, the tweeter at the top is giving more sound than the bottom speakers
Peter
Old Sep 18th, 2011, 04:29 PM
check the settings on your head unit as you have tweeters you'll have low and high pass filters that seperate the frequencys
Old Sep 18th, 2011, 05:14 PM
Just tried... still nothing
Peter
Old Sep 18th, 2011, 05:28 PM
oh well thats my limited knowledge of in car stereo, Im not sure what type of crossover you would have fitted for the tweeters and mids, it may be just capacitors on the speakers or a designated unit, maybe a problem with them or you have just killed all the speakers, Maybe an upgrade may be best if you have got to replace them so you dont blow them again, but someone else here hopefully will give you some advise as I dont tend to mess about with this sort of stuff....
Old Sep 19th, 2011, 10:09 AM
It's all original audio in the car. The back speakers are working perfectley well. I think it has something to do with the amp in the headunit, does anyone else have any suggestions???
Thanks for your help Stead.
Peter
Old Sep 22nd, 2011, 01:54 PM
Online
Ok, what you need to do is try some speakers that you KNOW work
in the front.
There is a possibility that the amplifier stage in the head unit is faulty.
The only sure way to find out is try a different head unit and speakers.
You should be able to, by the process of elimination, deduce which
component is faulty.
Hope this is of some use?
Tags: , ,
MCS front speakers not working but tweeters OK drozd First Generation Interior & Ice 0 Apr 15th, 2010 12:41 PM
Which is the live wire in the front and back speakers as im fitting new speakers fozworth First Generation Interior & Ice 3 Feb 10th, 2009 10:04 AM
Front speakers stopped working James First Generation Faults & Fixes 4 Jan 30th, 2008 04:33 AM
Front Speakers benmcguire First Generation Interior & Ice 6 Aug 7th, 2005 09:20 PM
Half of my speakers quit working! azimmerm First Generation Interior & Ice 4 Feb 27th, 2004 09:05 PM
