From memory you gonna need a special cage for it to fit properly, there dirt cheap and make a difference. Your also gonna need to find if you have flat pin or round pin harness and get the correct adaptor wiring harness to fit which is easy enough. If you want an aftermarket head unit take your pick! Aha any that take your fancy you can fit
pioneer do good ones with the USB connection on the back so you could wire it into the glove box and they do it with Bluetooth as well
