just done a very cheep 4 gauge install on my 04 mcs got the 4 clocks from ebay removed the speedo rev counter 2 screws from above behind the clocks unplug the wire then remove the 2 screws from the back and pull off the back of the speedo marked the spot for the gauges and drilled 2 holes 3/4 inch apart and looped a tie rap through then inserted the clock and tightened the tie rap reassemble run the wires down behind the column mount the other 2 near the cup holders the same way i used a sump plug adapter for oil temp sender and the pictured oil pressure adapter for oil pressure simply screwed the water temp sender in to the bleed screw hole in the top hose and drilled the inter-cooler and tapped it for the boost gauge used a ignition live for the lights
the gauges were £45 for all 4 bargin
sump adaptor £9
oil pres adaptor£9
my son thrashed it round the track at croft no rattles or movement and all worked fine
sump adaptor £9
oil pres adaptor£9
