How to replace the cigarette lighter luminous ring - MINI Cooper Forum
Go Back   MINI Cooper Forum > MINI Technical Forums > MINI Interior & ICE > First Generation Interior & Ice
Cigarette lighter and usb question Hewey Second Generation Interior & Ice 0 Nov 17th, 2013 08:44 PM
diagram for MINI cigarette lighter socket assembly? bjohn13 Second Generation Faults & Fixes 2 Mar 12th, 2013 09:40 PM
2007 MINI Cigarette Lighter Socket bjohn13 Second Generation Interior & Ice 0 Mar 1st, 2013 03:13 AM
HELP - how do intake the Cigarette Lighter fuse out Mid Life Mini Maintenance & MINI Care 8 Nov 9th, 2012 12:34 PM
Old Jan 1st, 2014, 09:37 PM
MangaGal's Avatar
Local Time: 02:39 AM
Australia
Hi guys
I recently discovered that the cigarette lighter luminous ring in my 2004 MC is broken. Everytime I try to pull the cigarette lighter out, the entire socket comes with it.
I checked and I think only the luminous ring (orange ring) is broken. But I don't know why the entire socket would come out with it too.
I stopped using the socket for anything except my sat nav which I require power.
Any chance anyone knows what I can do to fix it? I've tried supergluing it but when I used it, it came undone anyway.
Is it easy to replace?
Thanks. Much appreciated.
Old Jan 2nd, 2014, 02:10 PM
Local Time: 04:39 PM
Hi,
I think as it's already loose you may be able to remove it
without taking the whole thing apart.
The orange bit has clips on it that hold it in place.
As it seems like they have broken off, you should be able to lift it out.
There is a power cable connected underneath it.
Disconnect the old one and push re-fit the new one.
If you cannot do this it means removing the downtubes and unscrewing the whole bottom assembly to remove it.
Not that difficult..........just time consuming!
Hope this helps.
Old Jan 2nd, 2014, 08:54 PM
Hi ya
It can be done as stated above.
You can get the ring from the mini there not expensive
RealOEM.com * BMW R53 Cooper S Center console
Item 5
Also this may help
http://www.northamericanmotoring.com...r-housing.html
Just check the bulb is working in the orange ring before you put it back together
Hope this helps
Old Jan 2nd, 2014, 11:39 PM
MangaGal's Avatar
Australia
Thanks guys. I think I'll give it a try.
The trouble now is finding the replacement parts locally as ordering online would cost $US20 for shipping to Australia.
Thanks again.
Old Mar 18th, 2014, 09:01 AM
Local Time: 03:39 PM
Israel
I'm having the same problem so I'd like to replace the ring. Problem is that I can pull the whole thing about 1/2 way out, but no farther. I don't want to really force it. I'm afraid I'll break something.
Is it supposed to come out with a little force, or am I missing something?
Old Mar 18th, 2014, 05:02 PM
Online
Wrap a bit of sticky tape around it under the top lip and push it back in to make it a tighter fit?
Old Mar 18th, 2014, 07:45 PM
Israel
For the record: I played around a little bit and discovered that if you remove the metal lighter housing first, the plastic ring comes right out.
BTW, mine doesn't move around but comes out whenever I remove the lighter.
Old Mar 30th, 2014, 04:09 AM
MangaGal's Avatar
Australia
I still haven't fixed the ring. I have the same issue, when I pulled it out, it only came out half way. I can see the electric cable at the bottom. I'm trying got figure out how to disconnect it so that I can pull the whole thing out and replace the illuminious orange ring. I can't do it without taking the metal ring off because the orange plastic only comes out from the bottom.
» Recent Threads
Spare wheel 55 plate cooper
Today 01:32 PM
by ajn
Last post by The Nun
Today 03:24 PM
1 Replies, 34 Views
Mini One D - engine out, how difficult?
Jan 8th, 2014 09:36 PM
Last post by scott132
Today 03:19 PM
3 Replies, 659 Views
R52 A pillar interior trim removal
Today 08:11 AM
Last post by clockworks
Today 02:57 PM
2 Replies, 46 Views
Boot switch not working
Mar 8th, 2014 10:23 AM
Last post by burnstar
Today 11:04 AM
4 Replies, 385 Views
Attention to Detail (UK) - spot the difference!
Today 09:43 AM
by sailesh
Today 10:47 AM
1 Replies, 74 Views
Constant problems with my R50. Should I keep it or replace? Need advice please
Apr 3rd, 2014 03:52 PM
by kteara
Last post by kteara
Today 09:45 AM
13 Replies, 834 Views
Changing Oil????
Mar 3rd, 2014 12:32 PM
Last post by habi222
Today 09:31 AM
8 Replies, 709 Views
Strange Braking Noise
Jan 28th, 2014 08:27 PM
Today 09:21 AM
7 Replies, 938 Views
Electrical Issues with 2003 Cooper base
Mar 10th, 2014 07:09 PM
Today 09:05 AM
2 Replies, 426 Views
Mini Cooper S Rebuild
Today 07:49 AM
Last post by budgie2014
Today 07:49 AM
0 Replies, 52 Views
Cooper S Engine Rebuild
Today 07:44 AM
Today 07:44 AM
0 Replies, 52 Views
Does your Mini have a name?
Mar 25th, 2014 10:00 PM
Last post by johnnycatbiscuit
Today 04:26 AM
17 Replies, 1,030 Views
Engine mounts
Dec 22nd, 2013 07:47 PM
Today 04:21 AM
3 Replies, 784 Views
Buying a cat D insurance loss
Apr 4th, 2014 09:12 PM
Today 04:18 AM
9 Replies, 443 Views
Central Locking Problem Help
Yesterday 04:19 PM
Last post by heathwebbo
Today 12:17 AM
3 Replies, 185 Views
should I wait or not?
Apr 14th, 2014 12:07 AM
Last post by drozd
Today 12:08 AM
6 Replies, 390 Views
Lost locking wheel nut key
Apr 6th, 2014 10:49 AM
by Dazza88
Last post by drozd
Today 12:01 AM
3 Replies, 230 Views
NAVIGATION FIRMWARE dvd
Apr 5th, 2014 03:06 PM
Last post by drozd
Yesterday 11:47 PM
1 Replies, 200 Views
Mini One Silver 2004. FOR SALE
Yesterday 06:58 PM
by 93dlei
Last post by 93dlei
Yesterday 06:58 PM
0 Replies, 114 Views
Will this rear bike rack work on the Clubman?
Jun 6th, 2011 10:18 PM
Last post by sailesh
Yesterday 06:00 PM
3 Replies, 3,953 Views
Wheel & Tire Center
