New Stereo - MINI Cooper Forum
Go Back   MINI Cooper Forum > MINI Technical Forums > MINI Interior & ICE > First Generation Interior & Ice
Help with fitting after market stereo in R53 with HK speaker upgrade The Saints First Generation Interior & Ice 3 Sep 24th, 2013 04:26 PM
Mini 2006 - First Gen - Stereo System / Bluetooth / Controls holycow General Discussion 0 Jul 13th, 2013 06:12 PM
Mini r52 flat pin or round pin stereo harness? BigDaddy First Generation Interior & Ice 6 Feb 11th, 2013 10:59 PM
Mini Cooper S - Stereo, all stereo buttons are dead but CD still plays theboyjordan First Generation Faults & Fixes 0 Sep 18th, 2012 10:31 AM
Old Jan 2nd, 2014, 05:25 PM
Local Time: 03:11 AM
New Stereo
Folks - I've started to change the headunit in my partners 2004 mini one. Got the old one out and ordered the new harness etc for the round pin fittings. I've noticed that the new headunit had an RCA output at the rear - the old headunit had not and obviously nothing to connect to it. What shall I do? Do I need anything to put in there?
Old Jan 2nd, 2014, 07:41 PM
Local Time: 02:11 PM
Australia Male
Australia
The RCA outputs at the rear of the head unit are there to connect to an amplifier. Most head units have speaker level output through the harness and RCA for connection to an optional amplifier.
If your Mini doesn’t have the Harmon Kardon speaker system with an amp you should be fine by just connecting the new harness
Old Jan 2nd, 2014, 09:55 PM
Great .. thought so but I wasn't 100% sure. Thanks.
Old Jan 6th, 2014, 04:39 PM
All done. Stereo looks great and work a treat. My only concern is that the fascia adaptor doesn't hold the unit in securely - it doesn't move around by any means but you could pull the unit out through the adaptor if you wanted. Should the unit but secured into the dash by any other means? The fascia removes from the stereo so it doesn't matter too much - and it is tight but I was just wondering.
Old Jan 6th, 2014, 08:03 PM
Australia Male
Australia
The facia is not made to hold unit in, most units these days are held in using a cage that comes with the unit.
You place the cage in first and bend some tabs to clamp the cage into the dash. The head unit sides into the cage locking it into the cage with some sort of locking mechanism.
To remove the head unit you use the “keys” supplied with the unit that unlock the locking mechanisms to allow the unit to slide out of the cage.
Old Jan 7th, 2014, 04:00 PM
Got it! Removed everything today and locked the cage in with the tabs. I had to do abit of work to get the stereo to lock in as the fascia adaptor made the whole thing sit slightly forward but I sorted it. Thanks again.
» Hot Topics This Week
Mini Cooper N/A rally build - (80 replies)
Has any one got these? - (50 replies)
How to Retrofit the Spacesaver Spare Wheel - (43 replies)
Ok so who has ordered an F56 MCS? - (35 replies)
roof will not retract! - (32 replies)
» Recent Threads
Trunk Handle Cover
Today 02:39 AM
by iamtony
Last post by iamtony
Today 02:39 AM
0 Replies, 6 Views
Should i buy a Mini Cooper r50
Feb 14th, 2012 01:09 AM
by MENESS
Last post by Milpol
Today 12:58 AM
13 Replies, 7,909 Views
Replacement driver side door handle **new member**
Apr 14th, 2014 10:32 PM
Last post by The Nun
Yesterday 06:43 PM
3 Replies, 238 Views
R52 A pillar interior trim removal
Apr 18th, 2014 08:11 AM
Last post by clockworks
Yesterday 01:10 PM
3 Replies, 146 Views
Drivers Selt Belt PreTensionor / AirBag Fault Light
Yesterday 12:20 PM
Last post by da8addick
Yesterday 12:20 PM
0 Replies, 107 Views
Black rims for 195/55r16 run flats?
Mar 2nd, 2014 03:59 AM
Last post by habi222
Yesterday 12:18 PM
1 Replies, 352 Views
Tyre Sizes
Feb 17th, 2014 10:32 AM
by danb76
Yesterday 12:00 PM
3 Replies, 579 Views
Paint Code for Mini Steel Wheels
Mar 16th, 2014 03:59 PM
Yesterday 11:56 AM
6 Replies, 530 Views
Downgrading Rims
Mar 11th, 2014 09:52 AM
by Timbozy
Yesterday 11:51 AM
6 Replies, 502 Views
Adding multiple 12v power sockets / cigarette lighters and USB
Yesterday 11:47 AM
Last post by zero_cool
Yesterday 11:47 AM
0 Replies, 285 Views
Cup holder inserts
Apr 18th, 2014 06:23 PM
Last post by Mid Life Mini
Yesterday 11:45 AM
3 Replies, 173 Views
Does your Mini have a name?
Mar 25th, 2014 10:00 PM
Last post by Captain5691
Yesterday 11:39 AM
20 Replies, 1,157 Views
Help, is this a cooper S??
Apr 18th, 2014 09:29 PM
by markdm
Last post by markdm
Yesterday 01:29 AM
6 Replies, 236 Views
Cooper S Engine Rebuild
Apr 18th, 2014 07:44 AM
Last post by marque
Apr 18th, 2014 11:49 PM
1 Replies, 185 Views
O2 sensors in exhaust
Apr 18th, 2014 06:03 PM
Last post by marque
Apr 18th, 2014 11:24 PM
1 Replies, 153 Views
Mini Cooper S R56 Timing Chain Tensioner
Feb 24th, 2013 11:53 AM
Last post by MCMULC
Apr 18th, 2014 09:08 PM
9 Replies, 6,745 Views
Just bought mini what extras do I need to tell insurance about
Mar 19th, 2014 03:51 PM
Last post by JohnnyC
Apr 18th, 2014 07:43 PM
7 Replies, 670 Views
should I wait or not?
Apr 14th, 2014 12:07 AM
Last post by mab01uk
Apr 18th, 2014 07:10 PM
7 Replies, 490 Views
Constant problems with my R50. Should I keep it or replace? Need advice please
Apr 3rd, 2014 03:52 PM
by kteara
Apr 18th, 2014 07:03 PM
14 Replies, 1,008 Views
Spare wheel 55 plate cooper
Apr 18th, 2014 01:32 PM
by ajn
Apr 18th, 2014 07:00 PM
2 Replies, 123 Views
