| I'm trying to find out information about the phone mute voltages. I've read most of the posts for connecting the mute wire from a hands free kit to pin 10 of connector block A on the back of a head unit. Also in the post's I've read the voltage is +12 when the H/F unit is not in use and 0 volts when the H/F is in use. I've measured the voltage on my H/F mute wire it's about 11.5 volts when not in use and 3.5 Volts when in use. I can't get the radio to mute. I'm wondering if the +3.5 volts is the problem or if someone measured the voltage on their mute wire and if so what were the voltages. My only other guess is that I cooked the pin, because I soldered a wire directly to pin 10 and pulled it through the stock connector block. Thanks Jon M. |
| If this quote is right then my connection should at least mute the phone. I am connected to pin 10. Do you think it's the +3.5 Volts when the phone is in use. Instead of 0 Volts. If I'm reading the quote right and according to other posts that I've read I should at least get the head unit to mute. Thanks Jon |
| My kit only has the one wire going from 11.5 Volts when not in use to 3.5 Volts when in use. Thanks for the information. I'm wondering if I should try wiring the head-unit's switched power to the mute wire and see if the low voltage will switch it off. Well it's not so bad to turn down the volume, I'll probably just live with that for now. Thanks Jon |
| The kit I'm using is the new Sony Ericcson HCB-30 Bluetooth hands free kit. I measured the voltage with my cheapo Volt meter. Other than this the kit is working fine. The manual that came with the kit is a piece of junk. It has no specs at all. I looked around online but I can't find any other information. The kit has only been out I think since late november so there doesn't seem to be much information out there yet. If you hear anything about this kit let me know. Like I mentioned in a previous post it's not that big of a deal to turn down my stereo but it would be cool if the mute worked. Jon |
| Yes I have some Ideas Idea no1 you went to the wrong place to get it fitted 2,Bright idea,will kick your ass on Sunday 3,The stereo has been muted with an interface and the mute wire to the head unit has not been connected,this does not effect the operation just that it does not change the display To cure this problem refer to Idea No1 |
Hi john..... re idea no 1 - i know, but my boss had already paid for it for me.. otherwise i'd be in aberdeen like a flash, sunday?? - aberdeen social? i'll have to check my diary (i gotta move house this weekend or next!) kik my ass....not likely!!! see u later, g MINI Cooper, Chili Pack, Xenons, heated washers, MFSW, ASC+T, |
| moonshine, did you fit your interface or is it an aftermarket adapter like Autoleads? It sounds like the latter to me. These aftermarket adapters are generic in design to allow fitment to many different HU's. They really don't interact with the HU at all. Instead they work by using a relay to effectivley disconnect the speakers from the HU and connect them to the HF kit. This means lots of wires & cuts into your HU wiring loom. If you go the route of wiring your HF kit direct to the HU as JMotz is trying to do then the wiring is fairly simple and you will get the message on the HU. JMotz, When I did all the testing and exploration of this I never really checked the voltages. The simple check to test that the HU is still OK is just to ground pin. If I get chance I'll check my notes when I get home. It does sound as if the logic levels from your phone don't match the levels required by the HU. This will mean a little converter circuit. Hence why people go the Autoleads route. But it can still be done. |
| Well I've checked my notes and I did not note the voltages. If you have managed to test the HU by spimply taking pin 10 to ground and it worked then it would appear to be a issue with the logic levels. How up are you for a little simple electroinics? It may well be that with few simple components I can provide a solution. Over to you JMotz |
| Sorry Mike but this was not so in my case or the research I've done on my Boost HU. For the radio to mute and the display to say "PHONE" pin 10 needs to go low (0V). Thats all The other pin, pin 11 is used to active the speaker level input on the HU and power it up. Hence this needs +12V during a call or while the phone is switched on. And of course you will need to wire the speaker output of the HF to the telephone input on sub connector CB891-C pins 6(TEL+) & 12(TEL -). This is the one that you can leave live but not when the key is removed as you will risk the battery being flatened over long periods. The reason is that the +12V is used to power up in the front amplifier in the HU even if the HU is switched off. Otherwise you HF output would not be heard unless you had the HU on. Hope this clears things up. As you suggest Mike an aftermarket adaptor might be easier in this case. |
| Hands Free Phone Kit | sa3dos | First Generation Interior & Ice | 1 | Aug 7th, 2004 02:18 PM |
| DIY phone hands free fit instructions | mikeythemini | First Generation Interior & Ice | 0 | Dec 11th, 2003 11:18 PM |
| Hands free phone kit | d.griffiths | First Generation Interior & Ice | 3 | Sep 2nd, 2003 04:13 PM |
| Answering a hands free phone with MFSW | birmingham_smiths | First Generation Interior & Ice | 5 | Mar 17th, 2003 03:05 AM |
| Hands Free phone | Lewmar | First Generation Interior & Ice | 5 | Jul 23rd, 2002 04:38 PM |
