Help! Loose Wires Under Drivers Seat - MINI Cooper Forum
First Generation Interior & Ice
post #1 of 3 (permalink) Old Mar 10th, 2014, 04:25 PM Thread Starter
Local Time: 12:03 AM
Mini one, 57 plate, convertable.
Help needed.
My girlfriends mini was flooded due to a leak in the door seals. This required me to strip the entire car to take the carpet out and dry it (and fix the problem).
On taking out the carpet I found a couple of loose wires under the drivers seat. I have attached a picture and hope someone can tell me what these are for, how to fix it etc?
Nothing is actually not working in the car (apart from the radio that says DISABLED, but im assumin this was to do with me disconntecting the battery (?) )
Any help would be hugely appreciated.
Thank you.
Callum.
cwheathman is offline
post #2 of 3 (permalink) Old Mar 10th, 2014, 07:16 PM
Local Time: 01:03 AM
Quoted: 53 Post(s)
Does the passenger seat have something similar you can see thats connected to begin with?
If its just a spare plug connector it might be something to do with an option not fitted so not used, such as seat heaters?
The Nun is offline
post #3 of 3 (permalink) Old Mar 11th, 2014, 01:04 PM Thread Starter
the passanger seat does have the same from memory, its impossible to see what its connected too.
A suggestion has been that its the following:
"ok, they are NOT earth, they are the data link, they are why your radio says disable,"
Could this be the case?
Tags: , ,
Passenger seat mechanism different to drivers? Bossworld Second Generation Interior & Ice 6 Aug 12th, 2015 05:57 PM
Drivers seat lumbar support not working moblies First Generation Interior & Ice 4 Mar 9th, 2014 12:51 PM
Drivers Seat Slide Adjust Loose - Won't Lock Fully - SOLVED mcs_06 First Generation Faults & Fixes 3 Feb 9th, 2014 01:44 PM
Stereo upgrade: run new speaker wires or leave the stock ones in? 13ms13 First Generation Interior & Ice 4 Oct 2nd, 2013 06:21 PM
Unable to remove rear seat in '03 base Doorothie First Generation Faults & Fixes 0 Aug 23rd, 2012 08:23 PM
