Driver's seatback won't adjust? - MINI Cooper Forum
First Generation Interior & Ice
post #1 of 2 (permalink) Old Mar 11th, 2014, 06:37 PM Thread Starter
Local Time: 01:39 AM
Canada
We've got a 2003 that has an issue with the driver's seat back. It is stuck in a permanent semi recline position that is extremely uncomfortable to drive in. The recline adjust on the inboard side of the seat does not work. Is this repairable or do I need to replace the seat? I'd like to at least take a look at the machanics of it to see if it can be Mcgyvered into a more upright position. How do I remove the plastic back of the seat?
Any comments/suggestions would be appreicated.
Thanks,
Allan
Al T is offline
post #2 of 2 (permalink) Old Mar 11th, 2014, 09:23 PM Thread Starter
Canada
So, I was able to fix the issue based on a post on this site. Unfortunately since I haven't made 15 posts I can't attach a link to an "outside URL" even if it is from this site. Anyway, the info is here, you just have to look for it. It saved me the purchase of a new seat frame and a 6 hour drive. I really appreciate that. When I hit 15 posts I promise to attach the afore mentioned link.
Thank-you.
Allan
Al T is offline
Drivers Seat Slide Adjust Loose - Won't Lock Fully - SOLVED mcs_06 First Generation Faults & Fixes 3 Feb 9th, 2014 01:44 PM
