Amplifier Installation - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 2nd, 2003, 06:49 PM
MiniBil's Avatar
Send a message via AIM to MiniBil Send a message via MSN to MiniBil Send a message via Yahoo to MiniBil
Local Time: 02:44 PM
Hi.
I have a 2003 MCS. Just had the sound system upgraded. Added MB Quart 6.5" in the front, MB Quart 6x9's in the rear. Mounted the amplifier (Hifonics Zeus 8000 5-channel) in the boot.
Problem is, the battery is directly below the amp. This causes a high-pitched whine. Raising the amp minimizes the hum, though not a practical solution.
Waiting to have Dynamat Extremeliner installed under the amp in an attempt to quell the whine.
I've heard talk of people installing the amp under/inside the rear seats. Has anyone done or heard of this?
I searched the forum before asking this question and found no other reference.
Thank you,
MiniBil
Old Jan 2nd, 2003, 06:56 PM
Dom's Avatar
Dom
Test thread infiltrator
Send a message via MSN to Dom
Local Time: 11:44 PM
England View Dom's British Racing Green & White 1st Gen MINI Cooper Profile
Sorry, you won't get it inside or under the rear seats
Old Jan 2nd, 2003, 07:00 PM
MiniBil's Avatar
Dang.
Any suggestions on how to eliminate the high-pitched whine? The whine's there even when the radio's off, as there is no remote off connection off the head unit, apparently.
MiniBil
PS - Nice installs on your Gallery page!
Old Jan 2nd, 2003, 08:03 PM
Davbret's Avatar
I have my amps (all three) sitting on 3/4" MDF as part of the fiberglass amp/sub enclosure in my boot. Found that I needed really, really beefy grounds. Also, I made a sandwich of vinyl and aluminum (thick aluminum covered by thick vinyl on each side) that is between the bottom of the amps and the top of the MDF mounting board. This also helped. I'd say that it's still *barely* there. Due to the battery being under the boot floor, the only way to truly get around this would be to raise the amp up.
R
Dark Silver/Black MCS
Premium and Cold Packages
Space Cloth
Homepage and Stereo Mods
Old Jan 2nd, 2003, 08:52 PM
Local Time: 10:44 PM
Originally posted by MiniBil
Dang.
MiniBil
did you get this installed at a shop? they should be helping you with most of this, but here are some ideas.
first thing I would do is pull the RCAs out of the amplifier, does the whine still exist? This makes sure the problem is at the amp end and not the receiver.
dumb question, but which side did the installer run the rca preamp cables? i'm pretty sure there is a car powerline running on the drivers side.
did they have to run power to the HU? (only certain HUs required this)
next double check the ground point for the amp. i would use a point that is not used by another electrical device ( like the tail-lights etc) where did they ground the receiver? make sure there isn't a ground loop!!
how loud is the whine?
can you hear it idle or only under power?
have you shifted where the amp sits in the boot? I know that amp is kinda large, but I've found the drivers side of the boot to be "quieter" then the passengers side (well for my amp at least).
i recently went through this, so it's best to go in with a plan. i found that raising the amp (in height) did little good. I still have a slight whine at around 3000 rpm, but i'm still working that out (as is the case with all things car stereo!)
Old Jan 2nd, 2003, 09:08 PM
MiniBil's Avatar
Thanks to both Davbret and Minhi -- Nice rig, Davbret!
minhi, what's an "HU"?
I'll check the grounding points (I think I recall them grounding the amp directly to the battery ground lug) and positioning of the RCA cable runs when we install the lead shielding tomorrow. I'll also let you know if the shielding helps.
The whine is only evident with the engine on and rev'd. The higher the RPMs, the louder the whine.
Davbret, you mentioned really, really beefy grounds. Are you referring to the wire gauge? If so, what gauge wire did you use and where did you place the ground?
Thanx, again!
MiniBil
Old Jan 2nd, 2003, 09:13 PM
MiniBil
that's headunit (HU), if they grounded to the battery lead, then that should be a sufficient ground. you should still verify that the headunit is properly grounded (otherwise you could have a ground loop).
Old Jan 2nd, 2003, 09:22 PM
ToreB's Avatar
Norway View ToreB's Chili Red & White 1st Gen MINI Cooper S Profile
Space for amplifier
There's a cavity under the passenger seat, under the carpet. I believe this is the space for satnav equipment, but there is a styrofoam insert in my car.
It should be possible to hide an amp there, some cuts in the carpet will give more room as well.
Here's a simple drawing of the dimensions of the insert.
Regards, Tore
Name:	styro insert.jpg
Old Jan 2nd, 2003, 09:24 PM
MiniBil's Avatar
Oh, yeah...Head Unit. Sorry. I seem to have experienced a small bout of cranial rectumitus on that one.
I left the stock head unit in, by the way. Didn't want to lose the MFSW stuff.
MiniBil
Old Jan 2nd, 2003, 09:28 PM
MiniBil's Avatar
Thanx, ToreB -- Unfortunately, I have the Nav unit installed there.
MiniBil
Old Jan 2nd, 2003, 09:39 PM
minibil are you running the stock headunit?
that would change my thoughts on this...
Old Jan 2nd, 2003, 09:41 PM
MiniBil's Avatar
Yes, I am using the stock head unit.
Tell me more! Tell me more!
MiniBil
Old Jan 2nd, 2003, 09:42 PM
IBMiniG's Avatar
Local Time: 03:44 PM
I'd run a at least a 10 gauge ground from the head unit to the amp/batt ground. try to avoid other wires on the way. I bet the MB's sound great, had them in my last ICEd out car. did you have to trim the sheet metal for the fronts or did spacers buy enough room? crossovers in the doors? seems like your combo should sound nice and clean.
WARNING-Objects in rear view mirror have a tendency to disappear!
9/20 build '03 MCS IB/W/W, everything but the NAV & Sunroof
Old Jan 2nd, 2003, 09:55 PM
MiniBil's Avatar
Great! I'll make sure they run a 10 gauge the way you describe. I had it installed by a local sound shop here in Northern California. This is the first Mini they've installed.
The speakers were straight drop-in swaps. Yes, crossovers are in the doors.
I'm not crazy with the sound, just yet. I'm having them remove the Hifonics amp to replace with an Eclipse (Fujitsu Ten) 5-channel. You can see specs (no picture) here: .http://www.eclipse-web.com/products/amp/36501.html
The MB Quart front speakers use titanium tweeters. They sound kinda hot. When they're done and I get the sound balanced, I think it'll rock.
MiniBil
  #15 (permalink)
Old Jan 2nd, 2003, 10:43 PM
i would run 8 gauge for the ground/power (the battery is right there, so it's not that expensive!) knowing davebret, i suspect he has 4 or even 0
are you sure the mbquarts are direct drops? looking at the mounting depth they would need spacers to lift them out of the door. i think mb quarts come with an adaptor for offset mounting holes? which is the other problem you have to overcome with door speakers.
i don't expect you to get much difference by swapping amps (unless the amp is just bad). you're limiting factor is the quality of the signal coming from the headunit and also that you're taking highlevel output from the headunit, converting it somehow to low level for the amp then converting it back to high level for the speakers.
Amplifier phallus First Generation Interior & Ice 2 Sep 19th, 2005 01:17 PM
Amplifier and Subwoofer Osiris First Generation Interior & Ice 2 Sep 6th, 2004 11:53 PM
Amplifier Installation In Boot Cubby Hole jd2_uk First Generation Interior & Ice 1 May 13th, 2004 06:10 PM
Help with amplifier wiring!!!! martinstaehr2003 First Generation Interior & Ice 2 Apr 8th, 2004 11:00 PM
Amplifier installation question JBOO First Generation Interior & Ice 18 May 2nd, 2003 12:32 AM
