For clarity, I thought I would start a new thread for this as the topic has already been covered in
many threads.
I collected the adapter from the dealer today, who confirmed that it is
NOT listed as a Mini Part and that he found it by chance. BMW in Munich confirmed that this part number, for the E46 (BMW 3-series) does work in the Mini - in the Boost series of Radios from 09/2002:
Part No.: 65 12 0 153 502 - Auxillary connector.
Here is the contents of the box - the installation instructions are not contained, and would have to be printed out by the dealer for you - I didn't bother, as I had enough documentation thanks to Mini2:
On to the installation:
My new Mini seems to be totally missing any squeeks and rattles and so I didn't really want to totally dismantle the centre console - although I am grateful to Greatbear for his photos, another persons confirmation that it was possible without the disassembly encouraged me to follow his route.
My Mini is a LHD with the storage pack, meaning that I have the glove box etc.
Thanks to Greatbear's photo, I knew that the socket I wanted was on the left side of the radio (looking from the front) and could place it fairly accurately due to the other cables:
Thanks to a small camera, this is the radio from the side rear, fully installed:
I needed to get the plug into this space - lowest, rightmost hole, with the plugs 'locking tab' upwards:
Here is confirmation with the plug connected:
I then checked that it worked:
This is where the cable therefore hangs down - wrong side of the car for the glovebox (when it is LHD). This also shows the covering over the lower dashboard in this version:
To get the cable to the other side of the car, I found that the easiest path was behind this panel - no need to remove the screw (the cable is out of sight):
Inside the glove box, I chose to locate the socket here - high enough to miss the glove box arm, and (as I subsequently found out) - there is nothing directly behind this position:
The installation of the stereo plug to about 5 minutes, (apart from the photos), the fitting of the socket in the glove box is where my hand got hurt. The easiest way is to make sure that the socket hole is large enough and from the underneath, guide the socket onto a 'small rod' to get it through the hole - you need to take of the air pipe first (only loosely located):
Presumably others have done this quicker or better or differently, but it worked for me (total working time: just under 1 hour).
