| This could be quite tough, the whole dash is delivered per built for each car, and just slots in, its built as a complete unit before being delivered to the line. So to get it apart you really have to take the whole thing out, and then start removing bits from there. However, if your car has the shelf arrangement instead of the little cubby hole, and the glove box, things are not as bad. You should be able to find a way up and under this way. Thats why its hard for dealers to fix facia rattles. |
| Iv'e a post here on one of the Ipaq / nav threads that says if you remove the 2 panels at the end of the dash there's 2 screws at each side and that's all that holds the top of the dashboard. There's also an OEM fitting guide on here for a trafficpro nav system I think and it shows the top of the dash removed for GPS receiver intall. I have ipaq and tomtom 2, my GPS receiver is just sat on the dash top. I might get round to opening the dash top and putting it in there one day. |
| thnx for u'r reply mikemini, it doesn't matter where to pull first??? i can imagine that the plastic connections might break if i pull it on the wrong spot... don't wanna us doublesided tape afterwards hehe |
| Here is a link to step by step with pictures for removing the dashtop. http://mywebpages.comcast.net/sjbartnik/dash.html |
| heyhey guys, The Gps receiver is installed... normally it gets 9-11 fixes... but after putting the receiver under the dash, I get 7-9 fixes... tom tom needs 3 fixes sooo stil no problem.. anyway thnx for u'r help guys...here a pic without the dashboard, the location i used for the reciever is marked.... |
| rattle under dashboard | tendons | First Generation Faults & Fixes | 19 | Jul 3rd, 2009 01:55 PM |
| 05 Dashboard | johnny_g | First Generation Faults & Fixes | 0 | Sep 24th, 2006 08:50 PM |
| Dashboard lights | AndrewLondonUK | First Generation Faults & Fixes | 4 | Mar 26th, 2006 09:55 PM |
| Dashboard Disassembly? | RallyMINI | First Generation Interior & Ice | 0 | Nov 16th, 2004 06:31 PM |
| How do you remove the plastic dashboard? | Gar | First Generation Faults & Fixes | 22 | Sep 5th, 2003 08:11 PM |
