| OK, tried it, same Gazahs findings above in general, I'm getting volts at 140ish too............thought a car was 12volt in general? Lots of gobblegook numbers in that system............. |
| yeah paul... 140-ish --> 90 [or thereabouts i think] on starting the car --> back up to ~140! must be decivolts! so do you reckon it's realistic to think mini would either produce make or allow after-market production of a digital display to sit below the toggles displaying all the available [relevant] data! would be nice... |
| Here is (I hope) a complete list of all menu's. Translated from German and typed in by hand. Thank you for the appreciative applaus. ![]() Test 1.0 Chassis number 1.1 Kilometer count 1.2 Parts number 1.3 Coding-, Diagnostic- and Bus-index 1.4 Production Date (Calender week/year) 1.5 Hard- and Software status 1.6 Injectorstatus, Cylinder count, Engine factor. 2.0 Combisystem Test 3.0 Service intervall counter 4.0 Actual fuel consumption in l/100km. eg.0154 = 15,4 liters/100kms. 4.1 Consumption in liters/100kms. 5.0 Distance consumption in l/100kms. 5.1 Actual rest distance with available fuel in Kms. 6.0 Actual amount of fuel in tank. eg. 123321 =12,3liters left 32,1 liters right 6.1 Total amount of fuel in tank. 6.2 Show value of Fuel guage. 1= both senders OK, 2= sender failure, 3=ti signal unplausible (no reading) 7.0 Actual coolant temp. 7.1 Actual outside temp. 7.2 Actual engine revs. 7.3 Actual speed 8.0 Hexadecimal readings of menu 7.0 to 7.3 9.0 Actual on board voltage (Battery) 10.0 Land codes 11.0 Unit codes 12.0 No funktion 13.0 Gong test 14.0 - 14.4 On board diagnostic codes. eg 000000 = no failures 15.0 - 18.0 No funktion 19.0 On/Off for Test menu. 20.0 Correction factor for Fuel consumption Formula for correction: Shown consumption x 1000 / user defined consumption Push the trip reset button to begin the correction. Numbers count up from 0-9, when correct number shows push trip reset button. 20.1 Sets 10ths. for consumption factor 20.2 Sets 100ths. and 1000ths. for consumption factor 20.3 Saves the new consumption factor and shows new value 21.0 Software reset. (Same as disconnecting battery) Phew. I know some of it doesn't make sense (to me anyway) but there is some very useful info. in there. Push buttons and get wise... Passengers ride at own risk ! |
| I remember seeing Tony Pond kicking the crap out of a 6R4 he was doing shakedown tests on in a rally over here in the mid 80s........he ditched the car, got out, and did a Basil Fawlty on it, in the wilds of Donegal..........really funny......... ![]() It was a crazy car alright, sounded super.......... |
| Digital Info Display Issue | Stella1 | Canada | 1 | Jan 13th, 2007 10:12 PM |
| Digital Speed Display | SimonD | First Generation MINI Cooper S | 3 | Mar 22nd, 2005 10:19 PM |
| New DIY:How to show RPM, Fuel Levels, Speed and more on your Odometer Digital Display | Paul | General Discussion | 8 | Sep 20th, 2003 02:22 PM |
| Speed and RPM in each gear | Addicted_to_S | First Generation MINI Cooper S | 11 | Jun 23rd, 2002 07:30 PM |
